查看: 7618|回复: 5
[技术探讨] 新手桥接homeassistant和homebridge失败,是什么原因?
发表于 2019-12-14 17:21:02 | 显示全部楼层 |阅读模式
按照网上教程设置好config.json之后,重启homebridge,进入homebridge的web ui提示homebridge服务未运行,打开日志提示
config.json配置文件代码如下,是哪里不对么:
    "bridge": {
        "name": "Homebridge E56D",
        "username": "0E:FB:E0:A2:E5:6D",
        "port": 53118,
        "pin": "031-45-154"
    "accessories": [],
    "platforms": [
            "platform": "HomeAssistant",
            "name": "HomeAssistant",
            "host": "http://127.0.0.1:8123",
            "password": "",
            "supported_types": [
                "binary_sensor",
                "climate",
                "cover",
                "fan",
                "garage_door",
                "device_tracker",
                "input_boolean",
                "light",
                "lock",
                "media_player",
                "rollershutter",
                "sensor",
                "scene",
                "switch"
            "default_visibility": "visible",
            "verify_ssl": false
发表于 2019-12-14 18:32:56 | 显示全部楼层
我的也是同样问题,好像是用户权限问题,我在docker装的,还没搞好
发表于 2020-1-5 14:53:12 | 显示全部楼层
楼主搞得了么
 楼主| 发表于 2020-1-7 00:01:45 | 显示全部楼层
没,直接放弃homebridge了
发表于 2020-1-7 10:27:56 | 显示全部楼层
zjhcr 发表于 2020-1-7 00:01
没,直接放弃homebridge了
这个我确定了,是homeassistant版本问题,退回到0.96后就可以使用了。 放弃homebridge挺好的,反正过时了
hbrl 手机认证
发表于 2025-2-24 20:02:03 | 显示全部楼层
请教一下冬瓜的haos盒子上面怎样安装Homebridge?
GMT+8, 2026-1-15 05:07 , Processed in 0.979038 second(s), 15 queries , MemCached On.
