查看: 8389|回复: 1
[求助] 关于HF天气不能使用的问题
发表于 2019-12-9 15:36:35 | 显示全部楼层 |阅读模式
本人刚刚入坑不久的新人,之前浏览前辈的帖子成功运行hf天气插件,但是见天突然不能使用了,不知道什么原因,请各位帮忙 看看,万分感谢,另外哪位知道天气插件中那个曲线如何自定义颜色和可以在点上显示数据的方法,也请告知,谢谢。
2019-12-09 15:22:43 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=53 from 2019-12-09 07:20:55.196519)
2019-12-09 15:22:43 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hf_weather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-09 15:26:42 ERROR (MainThread) [frontend.js.latest.201911196] http://192.168.22.25:8123/local/custom-lovelace/hf_weather-card/hf_weather-card.js:435:71 Uncaught TypeError: Cannot read property 'attributes' of null
2019-12-09 15:28:11 ERROR (MainThread) [frontend.js.latest.201911196] http://192.168.22.25:8123/local/custom-lovelace/hf_weather-card/hf_weather-card.js:435:71 Uncaught TypeError: Cannot read property 'attributes' of null
2019-12-09 15:29:51 ERROR (MainThread) [frontend.js.latest.201911196] http://192.168.22.25:8123/local/custom-lovelace/hf_weather-card/hf_weather-card.js:435:71 Uncaught TypeError: Cannot read property 'attributes' of null
PS:我确认城市代码和KEY都没问题,请问是不是雾霾天气的问题呢??
发表于 2020-2-8 05:46:58 | 显示全部楼层
不是key的问题,是因为获取返回的中文天气状态插件常量没有定义,手动添加报错的天气就行了。
GMT+8, 2025-12-23 16:18 , Processed in 0.073433 second(s), 5 queries , MemCached On.
