查看: 6944|回复: 1
请各位大神看一下这个是除了什么问题呢
发表于 2019-12-7 13:18:17 | 显示全部楼层 |阅读模式
ni刷了armbian 安装hass.io的时候遇到的这个情况
使用的是这个一键安装脚本
curl -sL -o install.sh https://raw.githubusercontent.co ... ter/install.shchmod a+x install.sh./install.sh
################# 发到论坛时,请把上方日志也一并粘贴发送 ################
Distributor ID: Debian
Description:    Debian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 5.3.0-rc6-aml-g12 (root@vbox) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #5.94 SMP PREEMPT Sun Sep 1 14:30:45 MSK 2019
Linux aml 5.3.0-rc6-aml-g12 #5.94 SMP PREEMPT Sun Sep 1 14:30:45 MSK 2019 aarch64 GNU/Linux
安装 hassio 失败,请将上方安装信息发送到论坛询问。脚本退出...
 楼主| 发表于 2019-12-7 13:57:42 | 显示全部楼层
[Warning] No AppArmor support on host.
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
Unit hassio-supervisor.service could not be found.
GMT+8, 2025-12-31 23:34 , Processed in 0.398848 second(s), 7 queries , MemCached On.
