楼主: hqs136413
[基础教程] MQTT 连接不上
 楼主| 发表于 2019-12-5 16:33:25 | 显示全部楼层
zxytddd 发表于 2019-12-5 15:46
[22:49:13][W][mqtt:127]: Couldn't resolve IP address for '10.0.40.222# mqtt服务器ip/域名'!
从这报错 ...
去掉注释:
[00:25:40][I][mqtt:162]: Connecting to MQTT...
[00:25:58][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:25:58][I][mqtt:162]: Connecting to MQTT...
[00:26:17][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:26:17][I][mqtt:162]: Connecting to MQTT...
[00:26:36][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:26:36][I][mqtt:162]: Connecting to MQTT...
[00:26:55][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:26:55][I][mqtt:162]: Connecting to MQTT...
[00:27:14][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:27:14][I][mqtt:162]: Connecting to MQTT...
[00:27:32][I][ota:046]: Boot seems successful, resetting boot loop counter.
[00:27:33][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:27:33][I][mqtt:162]: Connecting to MQTT...
[00:27:51][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:27:51][I][mqtt:162]: Connecting to MQTT...
[00:28:10][W][mqtt:247]: MQTT Disconnected: TCP disconnected.
[00:28:10][I][mqtt:162]: Connecting to MQTT...
发表于 2019-12-5 16:49:50 | 显示全部楼层
你可以用命令行手工运行mqtt那些调试工具 测试MQTT服务是不是正常
发表于 2019-12-5 17:12:50 | 显示全部楼层
你那mqtt服务器地址和esphome设备地址在一个网段么?如果不在,如何路由的?
mqtt放ha那没问题,IP相同,端口不冲突就可以。
mqtt需要用户名和密码么?如果需要,esphome设备设置了么?
 楼主| 发表于 2019-12-5 17:13:59 | 显示全部楼层
调试了  没问题
 楼主| 发表于 2019-12-5 17:19:02 | 显示全部楼层
mqtt放ha那没问题,IP相同,端 ...
在一个网段里面          首先    hass端   我开了一个MQTT服务器    测试了没问题     IP是:192.168.106.230      我添加进了hass的congiguration.yaml   。
                                  然后  在esphome端,yaml文件里面  添加了192.168.106.230    本地ip是:192.168.106.231
 楼主| 发表于 2019-12-5 17:22:38 | 显示全部楼层
hqs136413 发表于 2019-12-5 17:19
在一个网段里面          首先    hass端   我开了一个MQTT服务器    测试了没问题     IP是:192.168.10 ...
hass端    yaml配置文件  里面是:
mqtt:
      broker: 192.168.106.230
      username: mosquitto
      password: 123
      discovery: True
      discovery_prefix: homeassistant
 楼主| 发表于 2019-12-5 17:23:51 | 显示全部楼层
hqs136413 发表于 2019-12-5 17:22
hass端    yaml配置文件  里面是:
mqtt:
esphome端    yaml配置文件 是:
添加了 这个
mqtt:
  username: mosquitto
  password: 123
  birth_message:
    topic: phicomm_dc1/state
    payload: online
  will_message:
    payload: offline
  topic_prefix: phicomm_dc1
  discovery: True
发表于 2019-12-6 10:23:01 | 显示全部楼层
测试没有问题的话
discovery_prefix 相关的直接可以去掉
直接用topic
  discovery: True
topic_prefix 感觉也可以去掉 不然感觉话题变成了phicomm_dc1phicomm_dc1/state
发表于 2019-12-6 14:56:13 | 显示全部楼层
pc上可以装一个 MQTT explorer观察下mqtt服务器接收topic情况来判断!
另外,esphome那配正确wifi了么?
 楼主| 发表于 2019-12-6 15:07:31 | 显示全部楼层
另外,esphome那配正确wifi了么? ...
好像可以了
[22:59:01][I][mqtt:162]: Connecting to MQTT...
[22:59:01][I][mqtt:202]: MQTT Connected!
[22:59:01][I][app:058]: setup() finished successfully!
[22:59:02][I][app:100]: ESPHome version 1.14.3 compiled on Dec  5 2019, 22:57:47
[22:59:02][C][wifi:415]: WiFi:
[22:59:02][C][wifi:283]:   SSID:
[redacted]
[22:59:02][C][wifi:284]:   IP Address: 10.0.40.146
[22:59:02][C][wifi:286]:   BSSID:
[redacted]
[22:59:02][C][wifi:287]:   Hostname: 'esp8266'
[22:59:02][C][wifi:291]:   Signal strength: -29 dB ▂▄▆█
[22:59:02][C][wifi:295]:   Channel: 1
[22:59:02][C][wifi:296]:   Subnet: 255.255.255.0
[22:59:02][C][wifi:297]:   Gateway: 10.0.40.1
[22:59:02][C][wifi:298]:   DNS1: 221.228.255.1
[22:59:02][C][wifi:299]:   DNS2: (IP unset)
[22:59:02][C][switch.gpio:042]: GPIO Switch 'plug'
[22:59:02][C][switch.gpio:043]:   Pin: GPIO4 (Mode: OUTPUT)
[22:59:02][C][sw[C][logger:175]: Logger:
[22:59:02][C][logger:176]:   L[C][captive_portal:169]: Captive Portal:
[22:59:02][C][ota:029]: Over-The-Air Updates:
[22:59:02][C][ota:030]:   Address: esp8266.local:8266
[22:59:02][C][ota:032]:   Using Password.
[22:59:02][C][mqtt:051]: MQTT:
[22:59:02][C][mqtt:053]:   Server Address: 10.0.40.163:1883 (10.0.40.163)
[22:59:02][C][mqtt:054]:   Username:
[redacted]
[22:59:02][C][mqtt:055]:   Client ID:
[redacted]
[22:59:02][C][mqtt:057]:   Discovery prefix: 'homeassistant'
[22:59:02][C][mqtt:058]:   Discovery retain: YES
[22:59:02][C][mqtt:060]:   Topic Prefix: 'esp8266'
[22:59:02][C][mqtt:062]:   Log Topic: 'esp8266/debug'
[22:59:02][C][mqtt:065]:   Availability: 'esp8266/status'
[22:59:02][C][mqtt.switch:038]: MQTT Switch 'plug':
[22:59:02][C][mqtt.switch:039]:   State Topic: 'esp8266/switch/plug/state'
[22:59:02][C][mqtt.switch:039]:   Command Topic: 'esp8266/switch/plug/command'
GMT+8, 2025-12-30 08:03 , Processed in 1.562701 second(s), 11 queries , MemCached On.
