查看: 3382|回复: 1
[求助] 补充:hassio升级到102.3没有反应了!大神们帮看看!!!
发表于 2019-12-4 18:20:50 | 显示全部楼层 |阅读模式
之前运行都是好好的,hassio升级到最新的102.3后,管理页面打不开了!
补充:(portainr.io 就是9000那个能进;但hassio进不了,感觉是config文件的问题,改了命令和格式吗?) 之前的0.102.2都是好的!
log如下
2019-12-05 19:58:55 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-05 19:58:58 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=518 from 2019-12-05 11:22:22.034478)
2019-12-05 19:59:02 ERROR (MainThread) [custom_components.smartir] An error occurred while checking for updates. Please check your internet connection.
2019-12-05 19:59:04 ERROR (MainThread) [homeassistant.setup] Setup failed for customize: Integration not found.
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 406, in _async_add_entity
    await entity.async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py", line 132, in async_added_to_hass
    await self._subscribe_topics()
  File "/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py", line 199, in _subscribe_topics
    "qos": self._config[CONF_QOS],
  File "/usr/src/homeassistant/homeassistant/components/mqtt/subscription.py", line 83, in async_subscribe_topics
    await requested.resubscribe_if_necessary(hass, current)
  File "/usr/src/homeassistant/homeassistant/components/mqtt/subscription.py", line 40, in resubscribe_if_necessary
    hass, self.topic, self.message_callback, self.qos, self.encoding
  File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 436, in async_subscribe
    async_remove = await hass.data[DATA_MQTT].async_subscribe(
KeyError: 'mqtt'
KeyError: 'mqtt'
KeyError: 'mqtt'
  File "/usr/src/homeassistant/homeassistant/components/mqtt/light/schema_basic.py", line 209, in async_added_to_hass
  File "/usr/src/homeassistant/homeassistant/components/mqtt/light/schema_basic.py", line 534, in _subscribe_topics
    self.hass, self._sub_state, topics
KeyError: 'mqtt'
KeyError: 'mqtt'
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.setup] Error during setup of component light
  File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
    return loop.run_until_complete(main)
  File "uvloop/loop.pyx", line 1456, in uvloop.loop.Loop.run_until_complete
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 302, in setup_and_run_hass
    log_no_color=args.log_no_color,
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 148, in async_from_config_file
    config_dict, hass, enable_log=False, skip_pip=skip_pip
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 93, in async_from_config_dict
    await _async_set_up_integrations(hass, config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 374, in _async_set_up_integrations
    *(async_setup_component(hass, domain, config) for domain in domains_to_load)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 51, in async_setup_component
    return await task  # type: ignore
  File "/usr/src/homeassistant/homeassistant/setup.py", line 147, in _async_setup_component
    hass, config, integration
  File "/usr/src/homeassistant/homeassistant/config.py", line 756, in async_process_component_config
    p_integration = await async_get_integration_with_requirements(hass, p_name)
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 48, in async_get_integration_with_requirements
    hass, integration.domain, integration.requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 77, in async_process_requirements
    if pkg_util.is_installed(req):
  File "/usr/src/homeassistant/homeassistant/util/package.py", line 45, in is_installed
    return version(req.project_name) in req
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3137, in __contains__
    return self.specifier.contains(item, prereleases=True)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
    item = parse(item)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
    return Version(version)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
    match = self._regex.search(version)
TypeError: expected string or bytes-like object
  File "/usr/src/homeassistant/homeassistant/setup.py", line 172, in _async_setup_component
    hass, processed_config
  File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 261, in async_setup
    await component.async_setup(config)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 121, in async_setup
    await asyncio.wait(tasks)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
    return await _wait(fs, timeout, return_when, loop)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
    await waiter
concurrent.futures._base.CancelledError
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.setup] Error during setup of component fan
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/components/fan/__init__.py", line 89, in async_setup
    await waiter
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.setup] Error during setup of component media_player
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 223, in async_setup
    await waiter
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.setup] Error during setup of component climate
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 126, in async_setup
    await waiter
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.components.weather] Error while setting up platform met
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 158, in _async_setup_platform
    await asyncio.wait(pending)
    await waiter
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.setup] Error during setup of component sensor
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 54, in async_setup
    await waiter
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall group.set (c:52181fd4ed5b495395584439d12bcf56): object_id=all_fans, name=all fans, visible=False, entities=['fan.power_fan']>
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/core.py", line 1244, in _safe_execute
    await self._execute_service(handler, service_call)
  File "/usr/src/homeassistant/homeassistant/core.py", line 1261, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 238, in locked_service_handler
    await groups_service_handler(service)
  File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 267, in groups_service_handler
    **extra_arg,
  File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 488, in async_create_group
    await component.async_add_entities([group], True)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 252, in async_add_entities
    await waiter
2019-12-05 19:59:10 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform mqtt
    item = parse(item)
    await waiter
 楼主| 发表于 2019-12-4 18:22:47 | 显示全部楼层
博联导致的问题?
GMT+8, 2025-12-23 18:46 , Processed in 0.209431 second(s), 7 queries , MemCached On.
