楼主: dhso
[插件集成] 【更新】侧边栏高德地图插件发布,带实时路况,增加深.....
发表于 2023-5-11 12:49:41 | 显示全部楼层
201457751 发表于 2023-5-5 19:52
HAOS 23.05版本会出错
Logger: frontend.js.latest.202305032
Source: components/system_log/__init__.py: ...
同样的错误,找不到解决办法
发表于 2023-5-11 14:48:45 | 显示全部楼层
马克一下,回头搞搞
发表于 2023-5-15 15:40:55 | 显示全部楼层
感谢大佬分享~
lilt 手机认证
发表于 2023-5-17 17:45:10 | 显示全部楼层
In Home Assistant 2023.5 Polymer will no longer be provided by Home Assistant. If you use Polymer now, we recommend you switch to Lit. If you want to keep using Polymer, you will have to load Polymer yourself.
发表于 2023-5-29 12:35:45 | 显示全部楼层
Polymer被新版HA抛弃了,需要调整为Lit
https://developers.home-assistan ... eprecating_polymer/
发表于 2023-6-2 12:45:01 | 显示全部楼层
我也是显示一片空白
发表于 2023-6-3 02:16:02 | 显示全部楼层
为什么我弄的,显示空白?
发表于 2023-6-3 16:54:08 | 显示全部楼层
我弄了好几遍,也是显示空白
坐等楼主更新
发表于 2023-6-16 23:23:46 | 显示全部楼层
地图显示空白,期待楼主更新
发表于 2023-7-7 18:45:14 | 显示全部楼层
lilt 发表于 2023-5-17 17:45
In Home Assistant 2023.5 Polymer will no longer be provided by Home Assistant. If you use Polymer no ...
请问怎么自己加载 Polymer
GMT+8, 2026-1-14 06:00 , Processed in 0.853344 second(s), 11 queries , MemCached On.
