查看: 6673|回复: 3
[技术探讨] 新手请教一下和风天气怎么不能加载
发表于 2019-11-30 20:24:04 | 显示全部楼层 |阅读模式
日志中显示
2019-11-30 19:08:23 ERROR (MainThread) [homeassistant.components.weather] Error while setting up platform hf_weather
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/config/custom_components/hf_weather/weather.py", line 86, in async_setup_platform
    yield from data.async_update(dt_util.now())
  File "/config/custom_components/hf_weather/weather.py", line 383, in async_update
    self._temperature = float(all_result["now"]["tmp"])
KeyError: 'now'
请教大神如何解决
发表于 2019-12-22 16:54:05 | 显示全部楼层
同遇到这个问题,不知道怎么解决
发表于 2020-2-8 05:41:59 | 显示全部楼层
实况温度没获取出来,报错。
发表于 2020-2-11 18:14:37 | 显示全部楼层
努力中 我的也有问题
GMT+8, 2025-12-31 19:25 , Processed in 0.143760 second(s), 11 queries , MemCached On.
