查看: 7920|回复: 1
[技术探讨] 请问树莓版有何安全的方式升级 gcc?
发表于 2019-11-28 07:27:54 | 显示全部楼层 |阅读模式
启动 home asssistat时发现
Component error: mobile_app - /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.25' not found
上网下载glic2.25 想编绎glibc-2.2.5 又出现需要gcc 6.3版,请问树莓版有何安全的方式升级 gcc?
loading cache ./config.cache
checking host system type... armv7l-unknown-linux-gnu
checking sysdep dirs... sysdeps/arm/elf sysdeps/unix/sysv/linux/arm sysdeps/unix/sysv/linux sysdeps/gnu sysdeps/unix/common sysdeps/unix/mman sysdeps/unix/inet sysdeps/unix/sysv sysdeps/unix/arm sysdeps/unix sysdeps/posix sysdeps/arm/fpu sysdeps/arm sysdeps/wordsize-32 sysdeps/ieee754/flt-32 sysdeps/ieee754/dbl-64 sysdeps/ieee754 sysdeps/generic/elf sysdeps/generic
checking for a BSD compatible install... /usr/bin/install -c
checking whether ln -s works... yes
checking for pwd... /bin/pwd
checking build system type... armv7l-unknown-linux-gnu
checking for gcc... gcc
checking version of gcc... 6.3.0, bad
checking for gnumake... no
checking for gmake... no
checking for make... make
checking version of make... 4.1, bad
configure: error:
*** These critical programs are missing or too old:gcc make
*** Check the INSTALL file for required versions.
发表于 2019-11-28 09:29:00 | 显示全部楼层
有个东西叫 docker
GMT+8, 2026-1-1 01:31 , Processed in 0.215445 second(s), 6 queries , MemCached On.
