查看: 8679|回复: 6
[求助] esphome出现问题
发表于 2019-11-19 14:43:18 | 显示全部楼层 |阅读模式
python模块那边有问题
发表于 2019-11-19 14:44:53 | 显示全部楼层
你又不把日志放出来,我怎么知道哪错了
 楼主| 发表于 2019-11-19 14:46:36 | 显示全部楼层
Aiden1 发表于 2019-11-19 14:44
你又不把日志放出来,我怎么知道哪错了
我执行esphome livingroom.yaml run    (ubuntu14.04环境下)
  File "/usr/local/bin/esphome", line 7, in <module>
    from esphome.__main__ import main
  File "/usr/local/lib/python3.4/dist-packages/esphome/__main__.py", line 11, in <module>
    from esphome import const, writer, yaml_util
  File "/usr/local/lib/python3.4/dist-packages/esphome/writer.py", line 8, in <module>
    from esphome.config import iter_components
  File "/usr/local/lib/python3.4/dist-packages/esphome/config.py", line 13, in <module>
    import voluptuous as vol
  File "/usr/local/lib/python3.4/dist-packages/voluptuous/__init__.py", line 3, in <module>
    from voluptuous.schema_builder import *
  File "/usr/local/lib/python3.4/dist-packages/voluptuous/schema_builder.py", line 26, in <module>
    _Mapping = collections.abc.Mapping
AttributeError: 'module' object has no attribute 'abc'
 楼主| 发表于 2019-11-19 14:47:46 | 显示全部楼层
问题 在这里 (图片上传失败了):
发表于 2019-11-19 14:52:57 | 显示全部楼层
建议按照这个方法安装带有web界面的,方便你检查你写的有没有错误
https://bbs.hassbian.com/forum.p ... p;highlight=esphome
 楼主| 发表于 2019-11-19 14:55:20 | 显示全部楼层
https://bbs.hassbian.com/forum.php? ...
好的 谢谢啦,我试试这个
 楼主| 发表于 2019-11-21 11:30:25 | 显示全部楼层
输入esphome config/ dashboard之后       ubuntu就一直卡在这里
WARNING You're using ESPHome with python 2. Support for python 2 is deprecated and will be removed in 1.15.0. Please reinstall ESPHome with python 3.6 or higher.
INFO Starting dashboard web server on port 6052 and configuration dir config/...
GMT+8, 2025-12-23 22:28 , Processed in 0.138205 second(s), 8 queries , MemCached On.
