查看: 31902|回复: 22
[基础教程] Ubuntu智能家居应用之三:HomeBridge的安装
发表于 2017-8-13 19:33:35 | 显示全部楼层 |阅读模式
Ubuntu智能家居应用之一:Ubuntu Server16.04.3的安装https://bbs.hassbian.com/thread-829-1-1.html
Ubuntu智能家居应用之二:HomeAssistant、MQTT的安装和Samba的配置https://bbs.hassbian.com/thread-830-1-4.html
其实这之三 也不算是我自己写教程,因为这是老高在威锋网老早就发的 教程,我只是搬过来 组成一个系列而已。
安装命令如下:
sudo nano /etc/apt/sources.list
deb http://mirrors.aliyun.com/ubuntu/ yakkety main restricted
deb http://mirrors.aliyun.com/ubuntu/ yakkety-updates main restricted
deb http://mirrors.aliyun.com/ubuntu/ yakkety universe
deb http://mirrors.aliyun.com/ubuntu/ yakkety-updates universe
deb http://mirrors.aliyun.com/ubuntu/ yakkety multiverse
deb http://mirrors.aliyun.com/ubuntu/ yakkety-updates multiverse
deb http://mirrors.aliyun.com/ubuntu/ yakkety-backports main restricted universe multiverse
deb http://mirrors.aliyun.com/ubuntu/ yakkety-security main restricted
deb http://mirrors.aliyun.com/ubuntu/ yakkety-security universe
deb http://mirrors.aliyun.com/ubuntu/ yakkety-security multiverse
     ###如果已经编辑过源的话请忽略此处
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install -y samba screen git
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -    #####此处更新为安装nodejs8.x  以便后面博联插件接入教程的融合。
sudo apt-get install -y nodejs
sudo apt-get -y install libavahi-compat-libdnssd-dev
sudo npm install -g --unsafe-perm homebridge hap-nodejs node-gyp
cd /usr/lib/node_modules/homebridge/
sudo npm install --unsafe-perm bignum
cd /usr/lib/node_modules/hap-nodejs/node_modules/mdns
sudo node-gyp BUILDTYPE=Release rebuild
cd /
sudo npm install -g homebridge-homeassistant
homebridge           #####这里先运行一次程序######
######键盘输入Ctrl+C停止homebridge运行,将再次出现命令提示符######
cd /home/pi/.homebridge       ###这里的pi是Ubuntu的登录用户名,请修改为自己的用户名
###########键盘输入Ctrl+C停止,然后建立config.json配置文件########
sudo nano config.json
################鼠标右键粘贴如下内容######################
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [
    "platform": "HomeAssistant",
    "name": "HomeAssistant",
    "host": "http://192.168.1.200:8123",
    "password": "raspberry",
    "supported_types": ["fan", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"]
###################分界线#####################################
上面的内容,注意格式,粘贴完毕后,按键盘上的Ctrl+X键,输入 Y,保存退出。
另外:请注意这几段段代码
   "username": "CC:22:3D:E3:CE:30",   ###这个MAC地址,可以修改成自己树莓派的MAC地址###
   "port": 51826,                     ###通讯端口,可以修改,但我觉得不用修改###
   "pin": "123-45-678"                ###PIN码,任意修改,格式是XXX-XX-XXX,只能是数字####
###其中的192.168.1.200是你的Ubuntu的局域网IP地址####
###这个是密码,请输入Ubuntu的登录密码####
##############再次输入homebridge  回车,检查运行有没有错误########
####将homebridge设置成随系统启动######
cd /
sudo useradd --system homebridge
sudo mkdir /var/homebridge
sudo cp ~/.homebridge/config.json /var/homebridge/
sudo cp -r ~/.homebridge/persist /var/homebridge
sudo chmod -R 0777 /var/homebridge
cd /etc/default
sudo nano homebridge
#########将下面的内容复制粘贴进去,然后Ctrl+X,然后Y,回车,保存退出####
# Defaults / Configuration options for homebridge
# The following settings tells homebridge where to find the config.json file and where to persist the data (i.e. pairing and others)
HOMEBRIDGE_OPTS=-U /var/homebridge
# If you uncomment the following line, homebridge will log more
# You can display this via systemd's journalctl: journalctl -f -u homebridge
# DEBUG=*
cd /etc/systemd/system
sudo nano homebridge.service
[Unit]
Description=Node.js HomeKit Server
After=syslog.target network-online.target
[Service]
Type=simple
User=homebridge
EnvironmentFile=/etc/default/homebridge
ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS
Restart=on-failure
RestartSec=10
KillMode=process
[Install]
WantedBy=multi-user.target
cd /
sudo systemctl daemon-reload
sudo systemctl enable homebridge
sudo systemctl start homebridge
sudo systemctl status homebridge
sudo reboot      ####重启Ubuntu####
###最后,你想返回去修改PIN码,MAC地址等等参数,可以按以下命令行来做####
sudo systemctl stop homebridge         ###停止homebridge运行###
cd /var/homebridge                     ###进入目录###
sudo nano config.json                  ###编辑配置文件###
sudo reboot                            ###重启Ubuntu####
发表于 2017-8-13 21:47:28 | 显示全部楼层
谢谢楼主的系列教程,另外,帖子中的url自动识别很烦人,我教你去除它们:
方法参见这个贴:https://bbs.hassbian.com/thread-864-1-1.html
rray
发表于 2017-8-14 21:15:43 | 显示全部楼层
这个命令,是每一个sudo语句就一个回车吗?还是每一行就一个回车?
 楼主| 发表于 2017-8-15 13:49:08 | 显示全部楼层
每一行   一次回车
发表于 2017-8-30 21:52:14 | 显示全部楼层
很好的教程~
发表于 2017-9-18 20:43:37 | 显示全部楼层
自动启动没有成功求解
发表于 2017-10-14 15:17:15 | 显示全部楼层
ubuntu 安装出现这个root@ubuntu:/home/zhijian# sudo apt-get update
命中:1 http://mirrors.aliyun.com/ubuntu yakkety-updates InRelease
命中:2 http://mirrors.aliyun.com/ubuntu yakkety InRelease
命中:3 http://mirrors.aliyun.com/ubuntu yakkety-backports InRelease
命中:4 http://mirrors.aliyun.com/ubuntu yakkety-security InRelease
获取:5 http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease [14.9 kB]
忽略:5 http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease
已下载 14.9 kB,耗时 35秒 (421 B/s)
正在读取软件包列表... 完成
W: GPG 错误:http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY 9165938D90FDDD2E
W: 仓库 “http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease” 没有数字签名。
N: 无法认证来自该源的数据,所以使用它会带来潜在风险。
N: 参见 apt-secure(8) 手册以了解仓库创建和用户配置方面的细节。
N: 鉴于仓库 'http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease' 不支持 'amd64' 体系结构,跳过配置文件 'main/binary-amd64/Packages' 的捕获。
N: 鉴于仓库 'http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease' 不支持 'i386' 体系结构,跳过配置文件 'main/binary-i386/Packages' 的捕获。
N: 鉴于仓库 'http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease' 不支持 'amd64' 体系结构,跳过配置文件 'non-free/binary-amd64/Packages' 的捕获。
N: 鉴于仓库 'http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease' 不支持 'i386' 体系结构,跳过配置文件 'non-free/binary-i386/Packages' 的捕获。
N: 鉴于仓库 'http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease' 不支持 'amd64' 体系结构,跳过配置文件 'contrib/binary-amd64/Packages' 的捕获。
N: 鉴于仓库 'http://mirrors.aliyun.com/raspbian/raspbian jessie InRelease' 不支持 'i386' 体系结构,跳过配置文件 'contrib/binary-i386/Packages' 的捕获。
发表于 2017-10-28 02:33:05 | 显示全部楼层
貌似有坑
应该用 curl -sL https://deb.nodesource.com/setup | sudo -E bash -
 楼主| 发表于 2017-10-28 19:24:09 | 显示全部楼层
panyda 发表于 2017-10-28 02:33
貌似有坑
sudo apt-get install -y n ...
不管怎么样  反正我正确安装了。。
ABC 手机认证
论坛风云人物
发表于 2017-11-27 01:43:11 | 显示全部楼层
Ubuntu用树莓派的软件源
GMT+8, 2025-12-16 23:26 , Processed in 0.796851 second(s), 11 queries , MemCached On.
