查看: 9028|回复: 6
[基础教程] N1 蓝牙一直连不上天猫精灵的解决方法
发表于 2019-11-12 23:38:41 | 显示全部楼层 |阅读模式
[bluetooth]# pair 78:44:05:BC:12:0C
Attempting to pair with 78:44:05:BC:12:0C
[CHG] Device 78:44:05:BC:12:0C Connected: yes
[CHG] Device 78:44:05:BC:12:0C UUIDs: 00001108-0000-1000-8000-00805f9b34fb
[CHG] Device 78:44:05:BC:12:0C UUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[CHG] Device 78:44:05:BC:12:0C UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
[CHG] Device 78:44:05:BC:12:0C UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
[CHG] Device 78:44:05:BC:12:0C UUIDs: 0000111e-0000-1000-8000-00805f9b34fb
[CHG] Device 78:44:05:BC:12:0C ServicesResolved: yes
[CHG] Device 78:44:05:BC:12:0C Paired: yes
Pairing successful
[CHG] Device 78:44:05:BC:12:0C ServicesResolved: no
[CHG] Device 78:44:05:BC:12:0C Connected: no
[bluetooth]# connect 78:44:05:BC:12:0C
问题表现为, 配对成功后马上断开。
查看蓝牙状态
sudo service bluetooth status
Jan 09 19:12:46 raspberrypi bluetoothd[370]: Bluetooth daemon 5.23
Jan 09 19:12:47 raspberrypi bluetoothd[370]: Starting SDP server
Jan 09 19:12:47 raspberrypi systemd[1]: Started Bluetooth service.
Jan 09 19:12:47 raspberrypi bluetoothd[370]: Bluetooth management interface 1.9 initialized
Jan 09 19:12:47 raspberrypi bluetoothd[370]: Sap driver initialization failed.
Jan 09 19:12:47 raspberrypi bluetoothd[370]: sap-server: Operation not permitted (1)
nano /etc/systemd/system/bluetooth.target.wants/bluetooth.service
找到
ExecStart=/usr/lib/bluetooth/bluetoothd
改为
ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
如果提示缺少 A2DP:
apt install pulseaudio pulseaudio-module-bluetooth pavucontrol bluez-firmware
重启蓝牙
sudo systemctl daemon-reload
sudo service bluetooth restart
发表于 2019-11-19 10:18:33 | 显示全部楼层
N1用天猫精灵放歌?
 楼主| 发表于 2019-11-19 13:57:49 | 显示全部楼层
wwwlywj 发表于 2019-11-19 10:18
N1用天猫精灵放歌?
也可以tts
发表于 2020-2-20 16:29:29 | 显示全部楼层
跟着大神走,大妈带回家
wwek 手机认证
发表于 2020-2-26 23:10:04 | 显示全部楼层
感谢·········
发表于 2020-6-20 09:06:59 | 显示全部楼层
感谢大佬 正想弄这个
发表于 2023-6-15 19:55:27 | 显示全部楼层
如果出现,  Loading LTKs timed out for hci0
该如何解决
GMT+8, 2026-1-17 00:47 , Processed in 0.065430 second(s), 9 queries , MemCached On.
