查看: 12627|回复: 2
[新奇玩法] linux系统HA配置文件云备份
发表于 2019-11-7 18:56:07 | 显示全部楼层 |阅读模式
本人系统:ESXI Debian docker hassio 大佬的一键脚本安装
log 撑爆虚拟机导致各种崩溃
找了一个办法备份配置文件
利用cadaver连接坚果云的webdav进行云上传
配置请参考如下链接:
备份Linux系统数据到坚果云  https://www.jianshu.com/p/c577ab52e252
因不支持文件夹备份 所以压缩之后上传,sh脚本执行backup.sh  我直接创建了hassio这个目录 上传至此。目录先压缩 后执行上传脚本
#!/bin/sh
cd /usr/share/hassio/homeassistant
tar -zcvf /home/debian/HAbackup/storage.tar.gz .storage
tar -zcvf /home/debian/HAbackup/custom_components.tar.gz custom_components
tar -zcvf /home/debian/HAbackup/packages.tar.gz packages
tar -zcvf /home/debian/HAbackup/automations.tar.gz automations
tar -zcvf /home/debian/HAbackup/switch.tar.gz switch
tar -zcvf /home/debian/HAbackup/sensor.tar.gz sensor
tar -zcvf /home/debian/HAbackup/light.tar.gz light
tar -zcvf /home/debian/HAbackup/deps.tar.gz deps
tar -zcvf /home/debian/HAbackup/tts.tar.gz tts
cadaver https://dav.jianguoyun.com/dav/hassio/ < /usr/share/hassio/homeassistant/backup.txt
backup.txt
put /home/debian/HAbackup/storage.tar.gz
put /home/debian/HAbackup/custom_components.tar.gz
put /home/debian/HAbackup/packages.tar.gz
put /home/debian/HAbackup/automations.tar.gz
put /home/debian/HAbackup/switch.tar.gz
put /home/debian/HAbackup/sensor.tar.gz
put /home/debian/HAbackup/light.tar.gz
put /home/debian/HAbackup/deps.tar.gz
put /home/debian/HAbackup/tts.tar.gz
put /usr/share/hassio/homeassistant/.ios.conf
put /usr/share/hassio/homeassistant/configuration.yaml
put /usr/share/hassio/homeassistant/scripts.yaml
put /usr/share/hassio/homeassistant/known_devices.yaml
put /usr/share/hassio/homeassistant/customize.yaml
put /usr/share/hassio/homeassistant/.homekit.state
put /usr/share/hassio/homeassistant/secrets.yaml
put /usr/share/hassio/homeassistant/groups.yaml
put /usr/share/hassio/homeassistant/automations.yaml
put /usr/share/hassio/homeassistant/backup.txt
bye
文章没啥技术含量,主要是提供一个思路
按道理可以做到脚本的递归上传 一共十几个文件目录 就这么写吧
建议添加到crontab做定时备份
配置文件避免在windows下编辑 会有回车符等问题。。。。
目录结构是我自己的,大家自己修改
我直接将两个备份配置文件放在了config目录 以防配置文件变更
没时间写了……应该能说明白 不清楚的地方大家脑补
backup.zip
1.56 KB, 下载次数: 8
发表于 2020-8-10 08:01:24 | 显示全部楼层
感谢分享 感谢分享
发表于 2021-2-21 10:19:27 | 显示全部楼层
GMT+8, 2025-12-29 10:26 , Processed in 0.434836 second(s), 14 queries , MemCached On.
