楼主: roiff
[插件集成] (8-13更新)自制美的、格力空调HA插件,简化HK操作
发表于 2017-8-21 23:32:29 | 显示全部楼层
请教下
climate:
  - platform: midea
    host: 192.168.1.105
    mac: '34:ea:34:e7:f2:5a'
    target_sensor: sensor.rmpro_temperature
    target_temp: 27
这个添加到ha就出现错误日记,如下,不添加就正常,连日记都没有,你的插件也有安装了
不知道哪里出错了
错误日记
2017-08-21 23:24:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/setup.py", line 61, in async_setup_component
    return (yield from task)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
    result = next(coro)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/setup.py", line 160, in _async_setup_component
    conf_util.async_process_component_config(hass, config, domain)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/config.py", line 593, in async_process_component_config
    platform = get_platform(domain, p_name)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/loader.py", line 104, in get_platform
    return get_component(PLATFORM_FORMAT.format(domain, platform))
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/loader.py", line 142, in get_component
    module = importlib.import_module(path)
  File "/usr/lib/python3.4/importlib/__init__.py", line 109, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 2254, in _gcd_import
  File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
  File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 1129, in _exec
  File "<frozen importlib._bootstrap>", line 1467, in exec_module
  File "<frozen importlib._bootstrap>", line 1571, in get_code
  File "<frozen importlib._bootstrap>", line 1623, in get_data
PermissionError: [Errno 13] Permission denied: '/home/homeassistant/.homeassistant/custom_components/climate/midea.py'
教程狂人卓越贡献突出贡献
 楼主| 发表于 2017-8-22 00:02:23 | 显示全部楼层
新新人类 发表于 2017-8-21 23:32
请教下
climate:
  - platform: midea
权限不对啊 你不是用root权限考进去 ftp之类的把
eric 手机认证
卓越贡献
发表于 2017-8-22 16:28:58 | 显示全部楼层
菲神,更新最新的hass版本后出现了这样的错误。[custom_components.climate.gree_other] Unable to update from sensor: could not convert string to float: 'unknown'
意思是传感器获取后无法转换浮点数据,但是数据还是有显示的。请有空更新一下!感激!
教程狂人卓越贡献突出贡献
 楼主| 发表于 2017-8-22 16:46:37 | 显示全部楼层
eric 发表于 2017-8-22 16:28
菲神,更新最新的hass版本后出现了这样的错误。[custom_components.climate.gree_other] Unable to update  ...
...更新到多少? 我自己现在是0.52.0 dev版本 并没有问题啊
eric 手机认证
卓越贡献
发表于 2017-8-22 16:54:04 | 显示全部楼层
刚更新hass到0.51.2
教程狂人卓越贡献突出贡献
 楼主| 发表于 2017-8-22 17:10:26 | 显示全部楼层
eric 发表于 2017-8-22 16:54
刚更新hass到0.51.2
你回头把log文件 发到我qq私信好了,我看下
eric 手机认证
卓越贡献
发表于 2017-8-23 15:13:29 | 显示全部楼层
已发邮件!请注意查收QQ邮箱!谢谢!
发表于 2017-8-26 20:31:32 | 显示全部楼层
谢谢分享!!!!
发表于 2017-8-27 00:13:39 | 显示全部楼层
阅读权限好高,能帮忙下载下吗?
教程狂人卓越贡献突出贡献
 楼主| 发表于 2017-8-27 02:41:52 | 显示全部楼层
lylus 发表于 2017-8-27 00:13
阅读权限好高,能帮忙下载下吗?
这论坛有毒吧 你没法打开? 搞笑了 我都没设置任何权限
GMT+8, 2025-12-29 02:27 , Processed in 0.402257 second(s), 10 queries , MemCached On.
