查看: 6150|回复: 4
[求助] 各位大神,大方摄像头在nodered里面读不了。
发表于 2019-11-4 16:51:27 | 显示全部楼层 |阅读模式
大方摄像头在nodered里面读不了,说什么证书过期,帐号密码都是对的,在浏览器上能操作,但是一定要输一次帐号密码。
发表于 2019-11-5 09:24:02 | 显示全部楼层
关掉大方的https
 楼主| 发表于 2019-11-5 10:21:23 | 显示全部楼层
N大,大方的https在那关啊,在wed页面找过了,没有啊,麻烦你指明一下,谢谢。
发表于 2019-11-6 08:28:41 | 显示全部楼层
awdx48 发表于 2019-11-5 10:21
N大,大方的https在那关啊,在wed页面找过了,没有啊,麻烦你指明一下,谢谢。 ...
lighttpd 配置文件看看
 楼主| 发表于 2019-11-6 11:02:44 | 显示全部楼层
neroxps 发表于 2019-11-6 08:28
lighttpd 配置文件看看
N大,再麻烦你看一下,我乱改了一下,现在开不了机了
以下是文件lighttpd.conf的内容
cgi.assign = ( ".cgi" => "/bin/sh" )
$SERVER["socket"] == ":443" {
  ssl.engine = "enable"
  ssl.pemfile = "/system/sdcard/config/lighttpd.pem"
# Support letsencrypt SSL cert paths
# (we don't want to upgrade to SSL nor auth' this path)
$HTTP["url"] !~ "^/.well-known/(.*)" {
    auth.backend                = "htdigest"
    auth.backend.htdigest.userfile = "/system/sdcard/config/lighttpd.user"
    auth.require = ( "/" => ("method" => "basic", "realm" => "all", "require" => "user=root"))
    $HTTP["scheme"] == "http" {
        # capture vhost name with regex conditiona -> %0 in redirect pattern
        # must be the most inner block to the redirect rule
        $HTTP["host"] =~ ".*" {
            url.redirect = (".*" => "https://%0$0")
## enable debugging
#debug.log-request-header     = "enable"
#debug.log-response-header    = "enable"
#debug.log-request-handling   = "enable"
#debug.log-file-not-found     = "enable"
#debug.log-condition-handling = "enable"
## where to send error-messages to
server.errorlog             = "/tmp/lighttpd-error.log"
## CGI (etc) stderr log
server.breakagelog = "/tmp/lighttpd-cgi-stderr.log"
## accesslog module
accesslog.filename          = "/tmp/lighttpd-access.log"
GMT+8, 2025-12-23 20:45 , Processed in 0.167792 second(s), 6 queries , MemCached On.
