楼主: chiunownow
企业微信改版,使用方法更加接近官方notify
发表于 2019-11-13 10:31:07 | 显示全部楼层
回去后就试试。为了方糖一直停留在0.88,然后出现了各种莫名奇妙的问题。感谢楼主
发表于 2019-11-25 23:24:14 | 显示全部楼层
发纯文字正常,发送带图片的消息一直提示错误
2019-11-25 23:21:53 ERROR (SyncWorker_12) [custom_components.wechatwork.notify] Message failed to send. Error code 41015. missing content, hint: [1574695313_53_3c54537d516c9a34233477ec3dfa1780], from ip: 222.82.24.152, more info at https://open.work.weixin.qq.com/devtool/query?e=41015
参与人数 1金钱 +7 收起 理由
chiunownow + 7 以修复
发表于 2019-11-26 19:57:39 | 显示全部楼层
升级到0.102.2出问题了。。图片发不出去。下面是日志:
2019-11-26 19:53:03 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139688991029200] [Errno 2] No such file or directory: '/config/local/tv.jpg'
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
    connection.context(msg),
  File "/usr/src/homeassistant/homeassistant/core.py", line 1236, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/usr/src/homeassistant/homeassistant/core.py", line 1261, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 120, in async_notify_message
    await notify_service.async_send_message(**kwargs)
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/config/custom_components/wechatwork/notify.py", line 92, in send_message
    files = {media_type: open(path, 'rb')}
FileNotFoundError: [Errno 2] No such file or directory: '/config/local/tv.jpg'
大佬有空搞一下么
 楼主| 发表于 2019-11-27 15:55:26 | 显示全部楼层
2019-11-26 19:53:03 ERROR (MainThread) [homeassi ...
请检查文件是否存在,以及目录是否在白名单内
https://www.home-assistant.io/docs/configuration/basic/
发表于 2019-11-27 21:57:02 | 显示全部楼层
换了个错误...
Message failed to send. Error code 41015. missing content, hint: [1574862829_46_6b50c20aa54a69c2fe850df6169fbe61], from ip: 125.70.20.230, more info at https://open.work.weixin.qq.com/devtool/query?e=41015
跟楼上一样了
 楼主| 发表于 2019-11-28 13:51:30 | 显示全部楼层
hugh_jie 发表于 2019-11-27 21:57
换了个错误...
Message failed to send. Error code 41015. missing content, hint: [1574862829_46_6b50c ...
https://github.com/Chiunownow/ho ... rk-notify/releases/
已修复(大概是企业微信偷偷改了接口?我应该之前测试都是OK的)
发表于 2019-11-28 14:07:52 | 显示全部楼层
chiunownow 发表于 2019-11-28 13:51
https://github.com/Chiunownow/home-assistant-wechatwork-notify/releases/
已修复(大概是企业微信偷 ...
非常感谢,能用了
发表于 2019-12-3 21:06:21 | 显示全部楼层
@all也只能有一个人能收到,是不是不能一对多了
发表于 2020-2-12 16:43:33 | 显示全部楼层
这么好的文章必须顶起来!感谢大神分享
发表于 2020-4-5 09:32:32 | 显示全部楼层
这个推送方便,马一下先
GMT+8, 2026-2-3 11:48 , Processed in 1.731550 second(s), 14 queries , MemCached On.
