查看: 8439|回复: 2
[技术探讨] 关于一键安装docker+hassio脚本的求助!!!
发表于 2019-10-27 17:18:57 | 显示全部楼层 |阅读模式
周一手贱把N1重刷了armbian系统,已经更换了阿里云的源了,一键安装镜像总拉不下来,错误信息如下:error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n",应该是网络问题,用docker pull homeassistant/qemuarm-64-homeassistant:0.100.1和docker pull homeassistant/aarch64-hassio-supervisor:0.100.1命令把0.100.1拉取成功了,可是后面不会操作了,怎么运行呢。是不是还需要安装HASSIO呀。运行curl -sL https://raw.githubusercontent.co ... tall/hassio_install | bash -s -- -m aarch64bash: line 1: 404:: command not found,出现这个错误,不知道该怎么进行了。请各位大神帮忙解决下。谢谢啦。
发表于 2019-10-27 18:52:55 | 显示全部楼层
是不是命令输入错误了呀,直接上putty 啊,复制命令上
发表于 2019-12-31 13:07:33 | 显示全部楼层
github地址发生变化!
curl -sL "https://github.com/home-assistant/hassio-installer /hassio_install.sh" | bash -s -- -m
GMT+8, 2025-12-31 21:38 , Processed in 0.049826 second(s), 11 queries , MemCached On.
