查看: 7274|回复: 8
简易判断当前日期是否节假日的传感器,包含切换数据库
发表于 2019-10-21 22:48:45 | 显示全部楼层 |阅读模式
1. 安装postgre Sql等...
sudo apt-get update
sudo hassbian-config install postgresql
sudo nano /etc/systemd/system/[email protected]
2. 创建表,插入默认数据
CREATE TABLE HOLIDAY(ID INT PRIMARY KEY     NOT NULL,DATE           TEXT    NOT NULL,TYPE            INT     NOT NULL);
3. 配置config
shell_command:
  update_day_type: python3 /home/homeassistant/.homeassistant/myshells/holiday.py
4.安装python库
sudo pip3 install psycopg2
5. 创建一个holiday.py,放到shell_command指定的位置,如:/home/homeassistant/.homeassistant/myshells/holiday.py修改以下语句:对应库名,用户,密码,服务器信息
conn = psycopg2.connect(database="homeassistant", user="homeassistant",
                        password="homeassistant", host="127.0.0.1", port="5432")
# encoding: utf-8
import requests
import json
from time import gmtime, strftime
import psycopg2
date = strftime("%Y%m%d", gmtime())
github_url = "http://api.goseek.cn/Tools/holiday?date=" + date
print(github_url)
r = requests.get(github_url)
holiday_date = r.json()
get_day = holiday_date['data']
print(get_day)
# CREATE TABLE HOLIDAY(ID INT PRIMARY KEY     NOT NULL,DATE           TEXT    NOT NULL,TYPE            INT     NOT NULL);
print("Opened database successfully")
cur = conn.cursor()
sql = "UPDATE HOLIDAY set DATE =%s,TYPE=%d WHERE ID=1" % (date, get_day)
cur.execute(sql)
conn.commit()
print("Records update successfully")
conn.close()
6. 将该脚本放到ha所在电脑的系统当中, 路径与shell_command中一致
7. 配置一条自动化: 每天0点一分调用shell_command 中的py脚本
- alias: update_day_type
  initial_state: true
  trigger:
    - platform: time
      at: '00:01:00'
  action:
    - service: shell_command.update_day_type
8 .创建一个sql传感器
  - platform: sql
    db_url: postgresql://homeassistant:homeassistant@localhost/homeassistant
    queries:
      - name: DB size
        query: "SELECT (pg_database_size('homeassistant')/1024/1024) as db_size;"
        column: "db_size"
        unit_of_measurement: MB
      - name: day type
        query: "SELECT type FROM HOLIDAY where id=1;"
        column: "type"
9. 重启ha
应该没有遗漏了....
参与人数 1金钱 +20 HASS币 +20 收起 理由
Roger + 20 + 20 论坛有你更精彩!
发表于 2019-10-22 09:17:56 | 显示全部楼层
楼主操作骚的出奇???换数据库直接改代码是不是太硬核了???
https://www.home-assistant.io/in ... om-database-engines
看错了,大佬是自己写了一个python shell 来查询假日~
为何不考虑用 http://api.goseek.cn/
发表于 2019-10-22 14:54:15 | 显示全部楼层
真硬核,围观群众码一条
发表于 2019-11-4 09:38:55 | 显示全部楼层
楼主,你的第二步里,少了一个步骤“插入默认数据”吧
 楼主| 发表于 2019-11-23 22:45:28 | 显示全部楼层
neroxps 发表于 2019-10-22 09:17
[md]
~~楼主操作骚的出奇???换数据库直接改代码是不是太硬核了???~~
换了换了,不存数据库了,原生的http请求没法动态传日期,改成用command_line了,接收一下print就行了
# encoding: utf-8
import requests
import json
print(get_day)
 楼主| 发表于 2019-11-23 22:46:38 | 显示全部楼层
嗯,现在不用数据库了
 楼主| 发表于 2019-11-28 16:27:21 | 显示全部楼层
第二步少了一条,插入一条id为1的默认数据
 楼主| 发表于 2019-11-28 16:28:55 | 显示全部楼层
着急睡觉, 直接贴markdown文档进来就出错....
 楼主| 发表于 2019-11-28 16:30:52 | 显示全部楼层
第一步没写完:需要把homeassistant启动服务的前置条件添加一个: 在postgresql启动之后启动
GMT+8, 2025-12-15 23:58 , Processed in 1.184025 second(s), 9 queries , MemCached On.
