查看: 24890|回复: 16
[新奇玩法] 全功能版本 HomeKit警戒 小米网关警戒 双向联动
发表于 2019-10-15 22:54:42 | 显示全部楼层 |阅读模式
之前看到了raspberry0316 发表的 修改小米网关警戒在home app里的图标 这篇佳作地址:https://bbs.hassbian.com/thread-8156-1-1.html
可以在HomeKit界面同步小米网关警戒开关
受益匪浅……
本着活着就是折腾的精神
查阅群资料,借鉴另一大神 luzai 发布的 set_state 服务插件需要将 domain修改一下 改为 DOMAIN = 'alarm_control_panel'
地址:https://bbs.hassbian.com/thread-3870-1-1.html
通过直接识别及修改alarm_control_panel的state 来达到状态双向控制,根据条件执行在家 外出 夜间 三种警戒模式
示例配置:
configuration.yaml
alarm_control_panel:
  - platform: manual
    code: 0369
    pending_time: 10
    delay_time: 20
    trigger_time: 4
    disarmed:
      trigger_time: 0
    armed_home:
      pending_time: 0
      delay_time: 0
HomeKit如果设置过滤 在 include_domains:   加入alarm_control_panel
自动化设置代码已经OK 之前错误的使用了IOS设备追踪生成的设备 ios设备始终显示home wifi判断错误
现在已经完成正常使用 折腾了好多模板 原来是实体错误
#HomeKit警戒同步
# ###HomeKit控制开关小米警戒
- alias: alarm_sync_mi
  initial_state: true
  trigger:
    platform: state
    entity_id: alarm_control_panel.home
  action:
    service_template: >
      {% if states.alarm_control_panel.home.state == 'disarmed' %}
        switch.turn_off
      {% else %}
        switch.turn_on
      {% endif %}
    entity_id: switch.xiaomi_gateway_alarm
##小米网关警戒开关同步HomeKit警戒状态
##关闭警戒
- alias: alarm_close
  trigger:
    - platform: state
      to: 'off'
  action:
    - service: alarm_control_panel.set_state
      data:
        state: 'disarmed'
##在家警戒
- alias: alarm_arm_home
  trigger:
    - platform: state
      to: 'on'
      # for:
      #   minutes: 2
  condition:
    condition: and
    conditions:
      - condition: time
        after: '08:00'
        before: '21:00'
      - condition: or
        conditions:
          - condition: state
            entity_id: device_tracker.*
            state: 'home'
          - condition: state
            state: 'home'
  action:
      data:
        state: 'armed_home'
##夜间警戒
- alias: alarm_arm_night
  trigger:
    - platform: state
      to: 'on'
      # for:
      #   minutes: 3
  condition:
    condition: and
    conditions:
      - condition: time
        after: '21:01'
        before: '07:59'
      - condition: or
        conditions:
          - condition: state
            state: 'home'
          - condition: state
            state: 'home'
  action:
      data:
        state: 'armed_night'
##外出警戒
- alias: alarm_arm_custom_bypass
  trigger:
    - platform: state
      to: 'on'
      # for:
      #   minutes: 3
  condition:
    condition: and
    conditions:
      # - condition: time
      #   after: '00:00'
      #   before: '23:59'
      - condition: state
        state: 'not_home'
      - condition: state
        state: 'not_home'
  action:
      data:
        state: 'armed_away'
set_state.py + 自动化配置.zip
1.81 KB, 下载次数: 37
参与人数 2金钱 +40 HASS币 +10 收起 理由
+ 20 + 10 我来瀚思就为看你!
咸味土豆 + 20 论坛有你更精彩!
发表于 2019-10-16 09:44:22 | 显示全部楼层
关注,膜拜,一气呵成
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-10-16 12:48:50 | 显示全部楼层
支持折腾~~
North丶
活跃会员卓越贡献
发表于 2019-10-16 18:32:42 | 显示全部楼层
嗯 多些思路多些玩法
 楼主| 发表于 2019-10-17 00:14:25 | 显示全部楼层
raspberry0316 发表于 2019-10-16 18:32
嗯 多些思路多些玩法
自动化修改好了 实体错误导致一直在错误的尝试 哈哈
 楼主| 发表于 2019-10-17 00:16:58 | 显示全部楼层
hellolucas 发表于 2019-10-16 09:44
关注,膜拜,一气呵成
都是借鉴…………
 楼主| 发表于 2019-10-17 00:33:32 | 显示全部楼层
发表于 2019-10-17 10:47:56 | 显示全部楼层
感谢分享!
发表于 2019-10-21 22:07:55 | 显示全部楼层
强帖留名,慢慢研究
发表于 2019-10-22 09:26:16 来自手机 | 显示全部楼层
GMT+8, 2025-12-23 00:58 , Processed in 0.119054 second(s), 14 queries , MemCached On.
