查看: 10287|回复: 7
[基础教程] 温湿度传感器DHT12通过espeasy/esphome接入ha加 常用传感器接入
发表于 2019-10-12 20:09:40 | 显示全部楼层 |阅读模式
这是针脚说明
我用的是NodeMcu Lua WIFI V3
刷espeasy论坛有教程这里就不再说了设置图如下
接线
VDD-----3.3V
SDA-----D2(图中红圈的自己设置)
SCL------D1 (图中红圈的自己设置)
GND----GND
yaml代码
  - platform: mqtt
    state_topic: "/esptest/DHT12/Temperature"
    unit_of_measurement: °C
  - platform: mqtt
    state_topic: "/esptest/DHT12/Humidity"
    unit_of_measurement: "%"
esphome的方法不会希望有大佬可以教一下
esphome配置
substitutions:
  device_name: chuanganqi
  wifi_ssid: 'PDCN'
  wifi_password: '15646420'
  wifi_fast_connect: 'false'
  wifi_reboot_timeout: 0s
  ota_password: '123456'
  api_reboot_timeout: 0s
esphome:
  platform: ESP8266
  board: esp01_1m
web_server:
  port: 80
  css_url: https://esphome.io/_static/webserver-v1.min.css
  js_url: https://esphome.io/_static/webserver-v1.min.js
wifi:
  ssid: $wifi_ssid
  password: $wifi_password
  reboot_timeout: $wifi_reboot_timeout
  power_save_mode: none
  fast_connect: $wifi_fast_connect
logger:
api:
  reboot_timeout: $api_reboot_timeout
ota:
  safe_mode: true
  password: $ota_password
# Example output entry
  - platform: dht12
    temperature:
    humidity:
    update_interval: 10s
i2c:
  sda: 12
  scl: 13
  scan: True
sda和scl的针脚看图接
比如我的12和13就是GPIO12和GPIO13 也就是D6和D7
参与人数 1金钱 +20 收起 理由
+ 20 感谢楼主分享!
 楼主| 发表于 2019-10-13 23:05:12 | 显示全部楼层
门磁传感器这个有大佬的教程就不说了地址https://bbs.hassbian.com/thread-651-1-1.html
雨滴传感器
按照大佬的方法有点问题https://bbs.hassbian.com/thread-1613-1-1.html
要把Switch Button Type选为 normal switch
人体传感器
和门磁雨滴设置一模一样注意修改GPIO
espeasy的yaml
binary_sensor:
  - platform: mqtt
    state_topic: "/esptest/switch/menci"
    qos: 0
    payload_on: "1"
    payload_off: "0"
    device_class: opening
  - platform: mqtt
    state_topic: "/esptest/yudi/Rain"
    qos: 0
    payload_on: "0"
    payload_off: "1"
    device_class: moisture
  - platform: mqtt
    state_topic: "/esptest/PIR/PIR"
    qos: 0
    payload_on: "1"
    payload_off: "0"
    device_class: motion
esp8266的配置(这个我还没测试接入传感器,ha可以自动发现所有传感器)
上面的配置通用
binary_sensor:
  - platform: gpio       #人体感应器
    pin:
      number: GPIO2
      mode: INPUT_PULLUP
发表于 2019-10-12 20:32:15 | 显示全部楼层
 楼主| 发表于 2019-10-12 20:44:07 | 显示全部楼层
Aiden1 发表于 2019-10-12 20:32
https://esphome.io/components/i2c.html
https://esphome.io/components/sensor/dht12.html
emmmm我一直在看dht12.。。。。。
我去瞅瞅
发表于 2019-10-12 23:03:35 | 显示全部楼层
感觉还是sonoff-CN简单点。主要是中文界面
发表于 2019-10-14 09:17:03 | 显示全部楼层
雨滴传感器
其实完全可以用ESPHOME接入的,门磁和人体我都接入了,雨滴传感器还在研究,身边没有那个传感器
 楼主| 发表于 2019-10-14 11:15:17 | 显示全部楼层
Aiden1 发表于 2019-10-14 09:17
其实完全可以用ESPHOME接入的,门磁和人体我都接入了,雨滴传感器还在研究,身边没有那个传感器 ...
因为懒就没试了
ms2 手机认证
发表于 2019-10-14 12:18:51 | 显示全部楼层
https://bbs.hassbian.com/thread-8390-1-1.html
我的,全部ESPHOME接入,简单得不得了
GMT+8, 2026-1-1 05:42 , Processed in 0.284978 second(s), 12 queries , MemCached On.
