查看: 9662|回复: 5
[求助] nodered(addon方式) 1880端口无法访问
发表于 2019-10-9 16:11:01 | 显示全部楼层 |阅读模式
悬赏20金钱未解决
N1+armbian+hassio+nodered(addon方式)遇到问题,报错如下。通过HA左侧菜单可以访问,但是独立访问ihttp://{ip}:1880不行,1880端口也不通。  看日志好像是nginx没启动,可能openresty版本有问题?
Welcome to Node-RED
9 Oct 15:22:58 - [info] Node-RED version: v0.20.8
9 Oct 15:22:58 - [info] Node.js  version: v10.16.3
9 Oct 15:22:58 - [info] Linux 5.1.0-aml-s905 arm64 LE
9 Oct 15:22:59 - [info] Loading palette nodes
9 Oct 15:23:06 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
9 Oct 15:23:07 - [info] Dashboard version 2.16.3 started at /endpoint/ui
9 Oct 15:23:09 - [info] Settings file  : /etc/node-red/config.js
9 Oct 15:23:09 - [info] Context store  : 'default' [module=memory]
9 Oct 15:23:09 - [info] User directory : /config/node-red/
9 Oct 15:23:09 - [warn] Projects disabled : editorTheme.projects.enabled=false
9 Oct 15:23:09 - [info] Flows file     : /config/node-red/flows.json
9 Oct 15:23:09 - [info] Starting flows
9 Oct 15:23:09 - [info] Started flows
9 Oct 15:23:09 - [info] Server now running at http://127.0.0.1:46836/
[15:23:09] INFO: Starting NGinx...
nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html)
9 Oct 15:23:14 - [info] [server:Home Assistant] WebSocket Connected to http://hassio/homeassistant
PANIC: unprotected error in call to Lua API (bad light userdata pointer)
发表于 2019-10-9 17:09:36 | 显示全部楼层
 楼主| 发表于 2019-10-9 19:55:45 来自手机 | 显示全部楼层
我确认了,配置是1880端口的,没错,但就是访问不了。看上面的日志,应该是ngnix没起来
发表于 2019-10-9 20:06:30 | 显示全部楼层
分享下呀,没看得太明白呀!
发表于 2019-10-9 21:35:04 | 显示全部楼层
我以前也碰到过,重装HA解决。。。(配备份好)
 楼主| 发表于 2019-10-11 18:56:16 来自手机 | 显示全部楼层
悲催啊,重新安装了一遍HA,仍然如此。所有用到nginx的addon docker都有这个问题
GMT+8, 2025-12-23 20:55 , Processed in 0.383904 second(s), 5 queries , MemCached On.
