查看: 6722|回复: 3
[求助] 求教,新版插件目录更改后,原来老插件的修改方法RI
发表于 2019-10-5 13:28:25 | 显示全部楼层 |阅读模式
                      之前坛里照着大大们写的插件和详细教程,依葫芦画瓢照抄着也勉强用上了
                谁知0.9几后那次的插件目录更改,L大大的彩云SE , C大的博联插件等。。。好多插件都用不了
              那位能告诉下修改方法或者帖上文件,学习下
                 感谢!
C大插件
https://bbs.hassbian.com/thread-584-1-1.html
HA版本 0.99.3
插件目录 custom_components\broadlink_mp1\switch.py
        \manifest.json
manifest.json内容
  "domain": "broadlink_mp1",
  "name": "Broadlink",
  "documentation": "https://www.home-assistant.io/components/broadlink",
  "requirements": [],
  "dependencies": [],
  "codeowners": []
报错日志
Log Details (ERROR)Sun Oct 06 2019 14:28:15 GMT+0800 (中国标准时间)
Error while setting up platform broadlink_mp1Traceback (most recent call last):  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for    return fut.result()  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run    result = self.fn(*self.args, **self.kwargs)  File "/config/custom_components/broadlink_mp1/switch.py", line 74, in setup_platform    persistent_notification = loader.get_component(hass,'persistent_notification')AttributeError: module 'homeassistant.loader' has no attribute 'get_component'
发表于 2019-10-5 18:59:19 | 显示全部楼层
搜 0.92 插件 或者 插件目录
 楼主| 发表于 2019-10-6 14:39:21 | 显示全部楼层
情非殇 发表于 2019-10-5 18:59
搜 0.92 插件 或者 插件目录
照着改报错。。。  也不知哪里不对
发表于 2019-10-7 07:29:11 | 显示全部楼层
homeassistant.loader.get_component(hass, comp_or_platform: str) → Optional[module][source]
Try to load specified component.
Looks in config dir first, then built-in components. Only returns it if also found to be valid. Async friendly.
GMT+8, 2025-12-23 20:55 , Processed in 0.310840 second(s), 5 queries , MemCached On.
