楼主: yyuanstudio
[已解决] 米家飞利浦智睿球泡自动化问题
发表于 2020-10-4 10:58:42 | 显示全部楼层
是不是这个类型不对?
model (Optional): The model of your light. Valid values are philips.light.sread1, philips.light.ceiling, philips.light.zyceiling, philips.light.moonlight, philips.light.bulb, philips.light.candle, philips.light.candle2, philips.light.mono1 and philips.light.downlight. This setting can be used to bypass the device model detection and is recommended if your device isn't always available.
发表于 2020-10-5 19:20:32 | 显示全部楼层
发表于 2020-11-10 23:48:10 | 显示全部楼层
模式哪个卡片怎么写?
发表于 2021-2-1 21:22:01 | 显示全部楼层
灯泡的配置文件能否发一下
GMT+8, 2025-12-22 23:12 , Processed in 0.233191 second(s), 7 queries , MemCached On.
