查看: 7031|回复: 6
[求助] /switches 下 一个yaml中多个MQTT开关应该怎么写啊 大神们?求教
发表于 2019-9-20 23:02:37 | 显示全部楼层 |阅读模式
试过多种方法都不对,请大神们指导啊
第一种
configuration.yaml  中 switch:!include_dir_list switchs
/switchs/shufangTC1.yaml 内容如下
platform: mqtt
state_topic: 'homeassistant/switch/d0bae46412c1/plug_0/state'
command_topic: 'device/ztc1/set'
payload_on: '{"mac":"d0bae46412c1","plug_0":{"on":1}}'
payload_off: '{"mac":"d0bae46412c1","plug_0":{"on":0}}'
platform: mqtt
state_topic: 'homeassistant/switch/d0bae46412c1/plug_1/state'
payload_on: '{"mac":"d0bae46412c1","plug_1":{"on":1}}'
payload_off: '{"mac":"d0bae46412c1","plug_1":{"on":0}}'
报错 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/switchs/shufangTC1.yaml contains duplicate key "platform". Check lines 0 and 6.
2019-09-21 14:04:20 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/switchs/shufangTC1.yaml contains duplicate key "name". Check lines 1 and 7
第二种
/switchs/shufangTC1-2.yaml内容如下
switch:
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_0/state'
    payload_on: '{"mac":"MAC","plug_0":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_0":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/MAC/plug_1/state'
    payload_on: '{"mac":"MAC","plug_1":{"on":1}}'
    payload_off: '{"mac":"MAC","plug_1":{"on":0}}'
报错ERROR (MainThread) [homeassistant.config] Invalid config for [switch]: required key not provided @ data['platform']. Got None. (See /config/switchs/shufangTC1-2.yaml, line 1). Please check the docs at https://home-assistant.io/components/switch/
第三种
/switchs/ketingTC1.yaml内容如下
  - platform: mqtt
    state_topic: 'homeassistant/switch/d0bae46447c4/plug_0/state'
    payload_on: '{"mac":"d0bae46447c4","plug_0":{"on":1}}'
    payload_off: '{"mac":"d0bae46447c4","plug_0":{"on":0}}'
  - platform: mqtt
    state_topic: 'homeassistant/switch/d0bae46447c4/plug_1/state'
    payload_on: '{"mac":"d0bae46447c4","plug_1":{"on":1}}'
    payload_off: '{"mac":"d0bae46447c4","plug_1":{"on":0}}'
报错ERROR (MainThread) [homeassistant.config] Invalid config for [switch]: expected a dictionary. Got [OrderedDict([('platform', 'mqtt'), ('name', 'ketingtc1_1'), ('state_topic', 'homeassistant/switch/d0bae46447c4/plug_0/state'), ('command_topic', 'device/ztc1/set'), ('payload_on', '{"mac":"d0bae46447c4","plug_0":{"on":1}}'), ('payload_off', '{"mac":"d0bae46447c4","plug_0":{"on":0}}')]), OrderedDict([('platform', 'mqtt'), ('name', 'ketingtc1_2'), ('state_topic', 'homeassistant/switch/d0bae46447c4/plug_1/state'), ('command_topic', 'device/ztc1/set'), ('payload_on', '{"mac":"d0bae46447c4","plug.... (See /config/switchs/ketingTC1.yaml, line 0). Please check the docs at https://home-assistant.io/components/switch/
到底应该如何填写? 求大神教导
发表于 2019-9-21 03:36:24 | 显示全部楼层
switch: !include_dir_merge_list switchs
 楼主| 发表于 2019-9-21 08:56:23 | 显示全部楼层
文件夹要改成switchs么?
我现在运行下面的实体都没什么问题,但一个YAML写多个实体就报错
.homeassistant\switche\loudaodeng.yaml
platform: mqtt
state_topic: "stat/sonoff2/POWER1"
command_topic: "cmnd/sonoff2/POWER1"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
其他的文件都是一个实体 不会报错   写在一起就报错
发表于 2019-9-21 10:54:09 | 显示全部楼层
riyue0000 发表于 2019-9-21 08:56
文件夹要改成switchs么?
.homeassis ...
是的,习惯上,多个文件,文件夹加s
 楼主| 发表于 2019-9-21 22:26:05 | 显示全部楼层
xuyang 发表于 2019-9-21 10:54
是的,习惯上,多个文件,文件夹加s
不是文件夹命名的问题 能贴下你的范例么,大神?
发表于 2019-9-22 04:24:17 | 显示全部楼层
你的写成了!include_dir_list switchs,
看清楚两者不同。merge,dir,不同
 楼主| 发表于 2019-9-24 22:38:29 | 显示全部楼层
好的  谢谢
GMT+8, 2025-12-23 22:36 , Processed in 0.047780 second(s), 5 queries , MemCached On.
