查看: 6374|回复: 4
home assistant 启动超时 求大佬帮忙看一下
发表于 2019-9-18 01:15:55 | 显示全部楼层 |阅读模式
开始 hassio 安装流程。(如出现 [Warning] 请忽略,无须理会)
[Warning] No AppArmor support on host.
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
[Info] Run Hass.io
等待 homeassistant 启动.............................................................................................................................................................................................................................................................................................................fail
########################### Docker images ###########################
REPOSITORY                                TAG                 IMAGE ID            CREATED             SIZE
homeassistant/aarch64-hassio-supervisor   188                 d78776eb356a        2 days ago          246MB
homeassistant/aarch64-hassio-supervisor   latest              d78776eb356a        2 days ago          246MB
homeassistant/qemuarm-64-homeassistant    0.98.5              5d180ed4d96c        7 days ago          1.07GB
homeassistant/qemuarm-64-homeassistant    latest              5d180ed4d96c        7 days ago          1.07GB
homeassistant/aarch64-hassio-dns          1                   e5edbd61b477        5 weeks ago         59.8MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                     COMMAND                  CREATED             STATUS              PORTS               NAMES
312052d388ed        homeassistant/aarch64-hassio-dns:1        "coredns -conf /conf…"   3 minutes ago       Up 3 minutes                            hassio_dns
a12cbc42bc64        homeassistant/aarch64-hassio-supervisor   "/bin/entry.sh pytho…"   3 minutes ago       Up 3 minutes                            hassio_supervisor
########################### hassio log ###########################
19-09-17 17:09:24 INFO (MainThread) [__main__] Initialize Hass.io setup
19-09-17 17:09:24 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/aarch64-hassio-supervisor with version 188
19-09-17 17:09:24 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-09-17 17:09:25 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/aarch64-hassio-supervisor:185']
19-09-17 17:09:25 INFO (MainThread) [__main__] Setup HassIO
19-09-17 17:09:25 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-09-17 17:09:26 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-09-17 17:09:26 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
19-09-17 17:09:26 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
19-09-17 17:09:26 INFO (MainThread) [hassio.host.info] Update local host information
19-09-17 17:09:26 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-09-17 17:09:26 INFO (MainThread) [hassio.host.services] Update service information
19-09-17 17:09:26 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-09-17 17:09:26 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-09-17 17:09:26 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-09-17 17:09:26 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-09-17 17:09:26 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-09-17 17:09:26 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/aarch64-hassio-dns with version 1
19-09-17 17:09:26 INFO (MainThread) [hassio.dns] Update resolv from Supervisor
19-09-17 17:09:26 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
19-09-17 17:09:26 INFO (SyncWorker_1) [hassio.docker.interface] Stop hassio_dns application
19-09-17 17:09:27 INFO (SyncWorker_1) [hassio.docker.interface] Clean hassio_dns application
19-09-17 17:09:27 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
19-09-17 17:09:28 INFO (SyncWorker_0) [hassio.docker.dns] Start DNS homeassistant/aarch64-hassio-dns with version 1
19-09-17 17:09:28 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/qemuarm-64-homeassistant with version 0.98.5
19-09-17 17:09:29 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-09-17 17:09:29 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-09-17 17:09:29 INFO (MainThread) [hassio.store] Load add-ons from store: 60 all - 60 new - 0 remove
19-09-17 17:09:29 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-09-17 17:09:29 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-09-17 17:09:30 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-09-17 17:09:30 INFO (MainThread) [hassio.discovery] Load 0 messages
19-09-17 17:09:30 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-09-17 17:09:30 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 1
19-09-17 17:09:30 INFO (MainThread) [__main__] Run Hass.io
19-09-17 17:09:30 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-09-17 17:09:30 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-09-17 17:09:30 INFO (MainThread) [hassio.core] Hass.io reboot detected
19-09-17 17:09:30 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-09-17 17:09:30 INFO (MainThread) [hassio.core] Hass.io is up and running
########################### homeassistant log ###########################
Error: No such container: homeassistant
homeassistant 启动超时,请检查上方日志....或者重启操作系统
重新刷有一次好了      但是后面又不行了  现在进不去:8123,弄了两个晚上了·······
发表于 2019-9-18 13:01:07 来自手机 | 显示全部楼层
我也是一样的情况,前面应该还有一个错误。搞了几天了……前几天还好着呢
 楼主| 发表于 2019-9-22 17:34:12 | 显示全部楼层
reedlxm 发表于 2019-9-18 13:01
我也是一样的情况,前面应该还有一个错误。搞了几天了……前几天还好着呢 ...
加个qq吧   一个人很难玩
 楼主| 发表于 2019-9-22 17:35:13 | 显示全部楼层
dtww1215 发表于 2019-9-22 17:34
加个qq吧   一个人很难玩
394004149,我现在好了  但是一装插件就进入不了hass,但是也不知道哪里错了
发表于 2019-9-29 16:51:27 | 显示全部楼层
dtww1215 发表于 2019-9-22 17:35
394004149,我现在好了  但是一装插件就进入不了hass,但是也不知道哪里错了 ...
我也好了,我猜测是网络问题docker的镜像数据错误,所以我在docker里把报错的部分删掉,重新下就好了。目前没什么毛病
GMT+8, 2026-1-1 07:44 , Processed in 0.730837 second(s), 14 queries , MemCached On.
