查看: 7267|回复: 0
0.98.5一直升级失败
发表于 2019-9-17 21:56:41 | 显示全部楼层 |阅读模式
查看日志提示
19-09-17 12:00:24 INFO (SyncWorker_11) [hassio.docker.interface] Update image homeassistant/armv7-addon-configurator:3.4 to homeassistant/armv7-addon-configurator:3.5
19-09-17 12:00:24 INFO (SyncWorker_11) [hassio.docker.interface] Pull image homeassistant/armv7-addon-configurator tag 3.5.
19-09-17 12:02:26 INFO (SyncWorker_11) [hassio.docker.interface] Stop addon_core_configurator application
19-09-17 12:02:28 INFO (SyncWorker_11) [hassio.docker.interface] Clean addon_core_configurator application
19-09-17 12:02:29 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/armv7-addon-configurator:3.4']
19-09-17 12:02:30 INFO (MainThread) [hassio.addons] Add-on 'core_configurator' successfully updated
19-09-17 12:02:33 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 3.5
19-09-17 12:16:15 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.98.5
19-09-17 12:16:15 INFO (SyncWorker_5) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.98.4 to homeassistant/raspberrypi3-homeassistant:0.98.5
19-09-17 12:16:15 INFO (SyncWorker_5) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.98.5.
19-09-17 12:52:34 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-09-17 13:19:14 INFO (MainThread) [hassio.host.info] Update local host information
19-09-17 13:19:14 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-09-17 13:19:15 INFO (MainThread) [hassio.host.services] Update service information
19-09-17 13:19:15 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-09-17 13:19:15 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-09-17 13:19:15 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-09-17 13:46:45 ERROR (SyncWorker_5) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.98.5 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.98.5: No such image: homeassistant/raspberrypi3-homeassistant:0.98.5").
19-09-17 13:46:45 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
这个英文应该是说没有找到镜像文件吧?
分不同的时间隔几天试一次,都是这个提示,是不是需要梯子?但是前几次的0.98.2升级到0.98.3到0.98.4都没有问题啊
GMT+8, 2026-1-1 07:42 , Processed in 0.400539 second(s), 6 queries , MemCached On.
