查看: 7954|回复: 2
[技术探讨] 请教关于data_template
发表于 2019-9-8 12:49:33 | 显示全部楼层 |阅读模式
service:
notify.mobile_app_<your_device_id_here>
data:
  message: Something happened at home!
  data:
    push:
      category: map
    action_data:
      latitude: "40.785091"
      longitude: "-73.968285"
You may also use a device_tracker for the latitude and longitude coordinates like so: "{{states.device_tracker.<your_device_id_here>.attributes.latitude}}" but make sure to use data_template in that case.
官方说明中,这里的经纬度参数如果用动态的,需要用data_template,不知道该怎么写,请高手指教,谢谢!
 楼主| 发表于 2019-9-8 13:18:18 | 显示全部楼层
我是这么写的
        push:
           category: map
         action_data:
#          latitude: "40.785091"
#          longitude: "-73.968285"
           latitude: '{{states.device_tracker.iphone_7.attributes.latitude}}'
           longitude: '{{states.device_tracker.iphone_7.attributes.longitude}}'
没有成功
 楼主| 发表于 2019-9-8 18:18:54 | 显示全部楼层
没人帮忙,自己解答一下吧
- service: notify.notifier_mian
     data_template:(写在这里)
      title: ***
       message: ***
       data:
         push:
           category: map
         action_data:
           latitude: '{{states.device_tracker.zhouyy.attributes.latitude}}'
           longitude: '{{states.device_tracker.zhouyy.attributes.longitude}}'
GMT+8, 2026-1-1 07:44 , Processed in 0.189428 second(s), 6 queries , MemCached On.
