查看: 13865|回复: 8
一代米家空调伴侣 TTL 搭接
发表于 2019-9-7 21:19:20 | 显示全部楼层 |阅读模式
受启发于 fung1006 的回帖( https://bbs.hassbian.com/forum.php?mod=redirect&goto=findpost&ptid=6565&pid=204766
以及教程 https://github.com/xcray/miio-by ... 6%E5%8A%9E%E6%B3%95
将一代米家空调伴侣拆解搭接 TTL 进入控制台,尝试开启 9898/udp,无奈失败。
实测该版本的固件并不存在 psm-set 和 psm-get 命令。
# help
help
system-conf
echo <on/off>
reboot reboot
sound-play <filename>
fm <3:KEY_PAUSE;4:KEY_PREV;5:KEY_NEXT>
check-pv-rate <unit: ms>
check-pv-get
测试对象:一代米家空调伴侣
型号:KTBL02LM
京东链接:https://item.jd.com/4230811.html
过程照片:
最后附上启动日志作为参考:
##[0]=boot2 start=0x0 size=0x6000
##[1]=psm start=0x6000 size=0x4000
##[2]=appfw start=0xa000 size=0x120000
##[3]=wififw start=0x13a000 size=0x30000
##[4]=wififw start=0x16a000 size=0x30000
##[5]=mcufw start=0x19a000 size=0x60000
##[6]=userdata start=0x1fa000 size=0x6000
##[7]=musicfw start=0x200000 size=0xc00000
##[8]=appfw start=0xe00000 size=0x120000
_|      _|  _|_|_|  _|_|_|    _|_|
_|_|  _|_|    _|      _|    _|    _|
_|  _|  _|    _|      _|    _|    _|
_|      _|    _|      _|    _|    _|
JENKINS BUILD NUMBER: 137
BUILD TIME: Nov 15 2016 10:39:38
BUILT BY: work
firmware: 1.4.1
MIIO APP VER: 151
MIIO WIFI VER: SD878x-193.104.9.p243-702.1.0-WM
MIIO MCU VER: 0148
APP Build Time: Apr 28 2019 15:22:31
active appfw addr = 0xa000
report_ota_state: "idle"
##AutoReset,Flag=0
[init] Initialized wireless stack
[MIIO-NORMAL-BOOT]
eSL_Init() in ====>>>>
[af] app_ctrl: prev_fw_version=0
=eSL_WriteMessage= t=9f02,l=0,data=
[net] Initialized TCP/IP networking stack
=recv zigbee message:Free=303552 ,t=8000;l=5;data= 00 00 9f 02 00
digital_did is 83788316
mac address is 7811dcf9c4fe
last four byte of key is 62743951
[MIIO-NORMAL-BOOT]
should start UAP
[af] app_ctrl [sta]: State Change: INIT_SYSTEM => UNCONFIGURED
[wlcm] Warn: NOTE: uAP will automatically switch to the channel that station is on.
[af] app_ctrl [uap]: State Change: UAP_INIT => UAP_STARTING
[af] app_ctrl [uap]: State Change: UAP_STARTING => UAP_UP
=eSL_WriteMessage= t=0010,l=0,data=
=eSL_WriteMessage= t=0f04,l=0,data=
eSL_Init() ====>>>>
FM Use 70 KB.
Ir_Zip_Get_CmdMapIrCode  u32Cmd = ffffff00
Ir_Zip_UpdateStatus_ByLastCmd() u32RemoteCMD[11011911], IrcodeLen[19]
current status[01011911]->eOnOff = 0  eMode = 1   eFan = 0  u8Diretor = 1  u8SetTemp = 25 bExtraFuncEn = 0, u8StatusIrCode = 1  bCmdType = 1
Ir_SpecialFun_QuickCool_Param_GetToPSM():0,10,30,
Ir_SpecialFun_QuickCool_Param_GetToPSM()-->bEnableQC[0], qc_time[10], Temp[30], ID[]
Initial-->()-->bEnableQC[0], qc_time[10], ID[]
Error:Ir_SpecialFun_GetPSM_SleepParam(2):psm_get_str
mi_i2s_set_freq 48KHz
                     ====>enter fac 55
=recv zigbee message:Free=195464 ,t=8010;l=6;data= 56 31 2e 34 38 00
Bind pro_ver=2
Bind_Info_Cfg version=9
Bind pro_ver=2
Bind right_partition=0x3
Bind pro_ver=2
Use P0 Table[0] num=1,bytes=41
Use P0 Table[1] num=0,bytes=0
Use P0 Table[2] num=0,bytes=0
Use P0 Table[3] num=0,bytes=0
Use P0 Table[4] num=0,bytes=0
=recv zigbee message:Free=192624 ,t=8000;l=5;data= 00 00 00 10 00
=recv zigbee message:Free=191136 ,t=8f04;l=7;data= 35 31 36 39 52 32 00
=recv zigbee message:Free=191136 ,t=8000;l=5;data= 00 00 0f
mi_i2s_init ok I2S_IRQn= 11
                           player starting......
SetFreq 44100
mi_i2s_set_freq 44.1KHz
                       u32PSM_K_1000X-->4685  4685
 04 00
gpio stat:1
audio mixer init done
                     find 0 channels on flash,temp_play=0
find_list = -1
dac_freq_set_ = 44100 , 44100
VerList sid=158d00030abef3,short_id=0x3522,ver=34 online=1
Creat Thread mi_ipc_looper
sche_new=1
=eSL_WriteMessage= t=001a,l=0,data=
=recv zigbee message:Free=163320 ,t=801a;l=12;data= ad 22 19 80 00 15 8d 00 02 16 05 9e
=recv zigbee message:Free=163320 ,t=8000;l=5;data= 00 00 00 1a 00
01-01  08:00:06.239
{"id":0,"method":"event.heartbeat","params":[{"I2S":292,"DL":0,"ZBUF":20,"FHEAP":127792,"MUS":217,"TIME":6,"RSSI":-256,"LUX":0,"FMS":0,"BRAND":151,"REMOTE_ID":67367,"AC_POWER":0,"AC_STATE":16849153}]}
发表于 2019-9-7 22:01:50 | 显示全部楼层
马一下,关注中
发表于 2019-9-7 23:32:08 | 显示全部楼层
谢谢分享
发表于 2019-9-8 12:01:14 | 显示全部楼层
一代使用中,等大佬,哈哈哈哈
发表于 2019-9-8 14:06:12 | 显示全部楼层
怎么区分1、2、3代??
 楼主| 发表于 2019-9-9 10:34:04 | 显示全部楼层
yylwhy 发表于 2019-9-8 14:06
怎么区分1、2、3代??
空调伴侣通过外形很容易区分。
普通网关:
二代比一代多了电台收音机、闹钟、安防提醒等功能,
三代还没出。
发表于 2020-3-14 17:13:53 | 显示全部楼层
感谢楼主热心分享
发表于 2020-10-17 02:21:40 | 显示全部楼层
想问下楼主,是怎么拆开米家空调伴侣的。弄了一天打不开,心态崩了
发表于 2021-1-25 20:20:49 来自手机 | 显示全部楼层
同问楼主,是如何拆开空调伴侣的,建议出个教程
GMT+8, 2025-12-29 14:15 , Processed in 1.836799 second(s), 21 queries , MemCached On.
