查看: 4907|回复: 6
[技术探讨] 进入hass.io 没有显示商店
发表于 2019-9-6 11:38:44 | 显示全部楼层 |阅读模式
<!DOCTYPE html><html lang="en"><head><link rel="preload" href="/frontend_latest/core.6e4a9dd6.js" as="script" crossorigin="use-credentials"><link rel="preload" href="/static/fonts/roboto/Roboto-Regular.woff2" as="font" crossorigin><link rel="preload" href="/static/fonts/roboto/Roboto-Medium.woff2" as="font" crossorigin><meta charset="utf-8"><link rel="manifest" href="/manifest.json" crossorigin="use-credentials"><link rel="icon" href="/static/icons/favicon.ico"><meta name="viewport" content="width=device-width,user-scalable=no"><style>body{font-family:Roboto,sans-serif;-moz-osx-font-smoothing:grayscale;-webkit-font-smoothing:antialiased;font-weight:400;margin:0;padding:0;height:100vh}</style><title>Home Assistant</title><link rel="apple-touch-icon" sizes="180x180" href="/static/icons/favicon-apple-180x180.png"><link rel="mask-icon" href="/static/icons/mask-icon.svg" color="#03a9f4"><meta name="apple-itunes-app" content="app-id=1099568401"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="msapplication-square70x70logo" content="/static/icons/tile-win-70x70.png"><meta name="msapplication-square150x150logo" content="/static/icons/tile-win-150x150.png"><meta name="msapplication-wide310x150logo" content="/static/icons/tile-win-310x150.png"><meta name="msapplication-square310x310logo" content="/static/icons/tile-win-310x310.png"><meta name="msapplication-TileColor" content="#03a9f4ff"><meta name="mobile-web-app-capable" content="yes"><meta name="referrer" content="same-origin"><meta name="theme-color" content="#03A9F4"><style>#ha-init-skeleton::before{display:block;content:"";height:112px;background-color:#03A9F4}</style></head><body><div id="ha-init-skeleton"></div><home-assistant></home-assistant><script>function _ls(e){var t=document.documentElement,s=t.insertBefore(document.createElement("script"),t.lastChild);s.defer=!0,s.src=e}window.Polymer={lazyRegister:!0,useNativeCSSProperties:!0,dom:"shadow",suppressTemplateNotifications:!0,suppressBindingNotifications:!0},"customElements"in window&&"content"in document.createElement("template")||document.write("<script src='/static/polyfills/webcomponents-bundle.js'><\/script>");var isS101=/\s+Version\/10\.1(?:\.\d+)?\s+Safari\//.test(navigator.userAgent)</script><script type="module" crossorigin="use-credentials">import "/frontend_latest/core.6e4a9dd6.js";
      import "/frontend_latest/app.6c0af079.js";
      import "/frontend_latest/hass-icons.cba69805.js";
      window.customPanelJS = "/frontend_latest/custom-panel.df6b4231.js";</script><script nomodule>(function() {
        // // Safari 10.1 supports type=module but ignores nomodule, so we add this check.
        if (!isS101) {
          window.customPanelJS = "/frontend_es5/custom-panel.5ad7d6c0.js";
          _ls("/static/polyfills/custom-elements-es5-adapter.js");
          _ls("/frontend_es5/compatibility.22a9b47c.js");
          _ls("/frontend_es5/core.3e996448.js");
          _ls("/frontend_es5/app.5785158b.js");
          _ls("/frontend_es5/hass-icons.5179bb27.js");
      })();</script></body></html>
Chrome  source
发表于 2019-9-6 15:08:41 | 显示全部楼层
访问不来GitHub?
发表于 2019-9-6 15:51:14 | 显示全部楼层
 楼主| 发表于 2019-9-6 16:16:39 | 显示全部楼层
sumwah 发表于 2019-9-6 15:51
商店地址有问题.
好的 谢谢 已经解决了!!!
发表于 2019-9-21 12:19:57 | 显示全部楼层
tankey 发表于 2019-9-6 16:16
好的 谢谢 已经解决了!!!
怎么解决的?我也有同样问题。
 楼主| 发表于 2019-9-22 19:40:54 | 显示全部楼层
roy0810 发表于 2019-9-21 12:19
怎么解决的?我也有同样问题。
是dns问题,你看看你的设备是不是设置了静态ip同时设定了DHCP绑定
发表于 2020-3-10 16:41:43 | 显示全部楼层
怎么解决的啊,我的也一样,我用exsi装的系统!
GMT+8, 2025-12-31 13:36 , Processed in 0.367508 second(s), 11 queries , MemCached On.
