楼主: tiger81
[技术探讨] 有用途强GT550在Traccar里面获取不到经纬度的吗?
发表于 2019-9-10 20:26:47 | 显示全部楼层
楼主能详细说一下你的环境吗?我也遇到和你一样的问题了,上报的信息倒是有经纬度,时区抽风一样,结果traccar里不更新位置了。。
我是用群晖docker安装的,配置如下:
<entry key='filter.enable'>true</entry>
    <entry key='filter.zero'>true</entry>
   <entry key='time.override'>deviceTime</entry>
    <entry key='time.protocols'>gt06</entry>
    <entry key='gt06.timezone'>28800</entry>
    <entry key='geocoder.enable'>ture</entry>
    <entry key='database.driver'>com.mysql.cj.jdbc.Driver</entry>
    <entry key='database.url'>jdbc:mysql://192.168.0.136:3307/traccar?serverTimezone=Asia/Shanghai&useSSL=false&allowMultiQueries=true&autoReconnect=true&useUnicode=yes&characterEncoding=UTF-8&sessionVariables=sql_mode=''</entry>
    <entry key='database.user'>traccar</entry>
    <entry key='database.password'>********</entry>
D大帖子里的NR纠偏,给设备发短信设置的GMT,E,0,0#。
 楼主| 发表于 2019-9-10 21:54:09 | 显示全部楼层
All you need to do is configure device to report UTC time. Only if that's not possible, you should set gt06 timezone configuration. Don't change anything else. Nothing else affects time.
去掉:
发表于 2019-9-12 20:18:42 | 显示全部楼层
tiger81 发表于 2019-9-10 21:54
All you need to do is configure device to report UTC time. Only if that's not possible, you should s ...
搞定了,感谢。就是路径是折线,不平滑
发表于 2021-7-26 17:43:36 | 显示全部楼层
谢谢分享,正在折腾。
我不生产技术,我只是技术的搬运工。
GMT+8, 2025-12-16 02:14 , Processed in 1.127286 second(s), 9 queries , MemCached On.
