查看: 7074|回复: 2
[已解决] systemctl自动启动部分组件出错
发表于 2019-8-22 12:17:30 | 显示全部楼层 |阅读模式
新手求助:
systemctl自动启动总是有一些组件错误,错误提示为 Network is unreachable,手动启动就没有问题
其中一次的错误日志:
2019-08-22 12:09:59 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform smtp
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/notify/__init__.py", line 73, in async_setup_platform
    platform.get_service, hass, p_config, discovery_info
  File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/smtp/notify.py", line 84, in get_service
    if mail_service.connection_is_valid():
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/smtp/notify.py", line 138, in connection_is_valid
    server = self.connect()
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/smtp/notify.py", line 122, in connect
    mail = smtplib.SMTP_SSL(self._server, self._port, timeout=self._timeout)
  File "/usr/lib/python3.7/smtplib.py", line 1031, in __init__
    source_address)
  File "/usr/lib/python3.7/smtplib.py", line 251, in __init__
    (code, msg) = self.connect(host, port)
  File "/usr/lib/python3.7/smtplib.py", line 336, in connect
    self.sock = self._get_socket(host, port, self.timeout)
  File "/usr/lib/python3.7/smtplib.py", line 1037, in _get_socket
    self.source_address)
  File "/usr/lib/python3.7/socket.py", line 727, in create_connection
    raise err
  File "/usr/lib/python3.7/socket.py", line 716, in create_connection
    sock.connect(sa)
OSError: [Errno 101] Network is unreachable
已经解决:启动systemd-networkd-wait-online.service这个服务就好了,新手对linux不太了解,不知道是什么原理
发表于 2019-8-22 12:28:35 | 显示全部楼层
对应的service 里面,[Unit] 里添加 After=network-online.target
 楼主| 发表于 2019-8-22 12:37:30 | 显示全部楼层
RobinVP 发表于 2019-8-22 12:28
对应的service 里面, 里添加 After=network-online.target
一直都添加着呢
GMT+8, 2025-12-16 00:00 , Processed in 0.423150 second(s), 11 queries , MemCached On.
