查看: 8416|回复: 4
[进阶教程] 魅族温湿度脚本获取数据
发表于 2019-8-19 23:41:07 | 显示全部楼层 |阅读模式
有兴趣的可以试试:
以下代码另存为一个python文件例如:meizu.py
import sys
from btlewrap import BluepyBackend
from btlewrap.base import BluetoothInterface
bt_interface = BluetoothInterface(BluepyBackend, adapter='hci0')
cmd_th = b'\x55\x03\x01\x11'
cmd_bt = b'\x55\x03\x01\x10'
handle = 48
def get_data(mac_addr):
    with bt_interface.connect(mac_addr) as connection:
        res = connection.write_handle(handle, cmd_th)
        if 'rsp' not in res:
            raise Exception()
        data = connection.read_handle(handle)
        temp10 = int.from_bytes(data[4:6], byteorder='little')
        humi10 = int.from_bytes(data[6:8], byteorder='little')
        temperature = float(temp10) / 100.0
        humidity = float(humi10) / 100.0
        res = connection.write_handle(handle, cmd_bt)
            raise Exception()
        battery = float(data[4]) / 10.0
        return temperature, humidity, battery
if __name__ == '__main__':
    if len(sys.argv) != 2:
        print("need mac addr.")
        sys.exit(0)
    mac_addr = sys.argv[1]
    print("-------GET Meizu Data: %s------->" % mac_addr)
    temperature, humidity, battery = get_data(mac_addr)
    print("temperature:%.2f,humidity:%.2f%%,battery:%.1fv" % (temperature, humidity, battery))
    print("-------FINISH GET-------<")
通过命令python3 meizu.py mac_addr
只测试了python3,并且因为依赖bluepy库,安装方法参考github,https://github.com/IanHarvey/bluepy
Jeff
活跃会员
发表于 2019-8-20 06:44:28 | 显示全部楼层
谢谢分享!
Jeff
发表于 2019-8-20 09:04:11 | 显示全部楼层
bluepy 之前就一直没搞定  对我来说就是修仙教程了...
mitu 手机认证
发表于 2019-8-20 09:25:44 | 显示全部楼层
    sudo apt-get install python3-pip libglib2.0-dev
    apt-get install -y python3-setuptools
    sudo apt-get install git build-essential libglib2.0-dev
    git clone https://github.com/IanHarvey/bluepy.git
    cd bluepy
    python3 setup.py build
    sudo python3 setup.py install
流水无味
灌水之王
发表于 2019-8-20 10:18:54 | 显示全部楼层
看不懂没事
论坛上次那个魅族的教程可以接入的(用的N1)
GMT+8, 2026-1-1 09:44 , Processed in 1.251215 second(s), 9 queries , MemCached On.
