查看: 7110|回复: 5
[已解决] 黑群晖安装套件版hassio之后设定检验出错。
发表于 2019-8-19 19:24:32 | 显示全部楼层 |阅读模式
文件的位置在\\ds3617xs\docker\hass.io\homeassistant\configuration.yaml
检验错误提示:File not found: /config/configuration.yaml
如果我把configuration.yaml放在\\ds3617xs\docker\hass.io\homeassistant\config\configuration.yaml则会提示File configuration.yaml not found.
我该怎么办,packages文件放在哪?之前忘了附上configuration.yaml的代码内容了
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 33.2642
  longitude: 114.52
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: <a href="http://en.wikipedia.org/wiki/List_of_tz_database_time_zones" target="_blank">http://en.wikipedia.org/wiki/List_of_tz_database_time_zones</a>
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
homekit:
group: !include groups.yaml
script: !include scripts.yaml
问题原因已找到,直接安装hassio和用docker安装homeassistant的情况是不一样的。换成docker安装后此配置一切正常,不再报错。
发表于 2019-8-19 20:50:09 | 显示全部楼层
黑群晖有VMM吗,我是白群,VMM有hassio的虚拟机镜像可以用。
流水无味
灌水之王
发表于 2019-8-20 07:40:38 | 显示全部楼层
就放 homeassistant 下别管
packages放在configuration.yaml同目录下
然后configuration.yaml里面
homeassistant:
话说群辉docker直接载入hassio的话各种环境都没设置
 楼主| 发表于 2019-8-20 12:45:11 | 显示全部楼层
按照L大的教程已经添加了语句,结果出现了上述问题。
 楼主| 发表于 2019-8-20 12:46:25 | 显示全部楼层
我用的是论坛大神做的hassio第三方套件
发表于 2019-8-20 14:41:49 | 显示全部楼层
如果黑裙也有vmm,可以直接用虚拟机镜像,导入就行了,简单的很。
GMT+8, 2025-12-16 01:50 , Processed in 1.046845 second(s), 11 queries , MemCached On.
