查看: 5709|回复: 7
[求助] 论坛订制的触摸开关,会不时断开,求助
发表于 2019-8-19 13:59:42 | 显示全部楼层 |阅读模式
[INFO] found mqtt on local database1566193899: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566193983: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194027: New connection from 192.168.1.158 on port 1883.1566194027: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194050: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194057: New connection from 192.168.1.158 on port 1883.1566194057: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194080: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194085: New connection from 192.168.1.158 on port 1883.1566194085: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194113: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194118: New connection from 192.168.1.158 on port 1883.1566194118: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194143: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194148: New connection from 192.168.1.158 on port 1883.1566194148: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194173: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194178: New connection from 192.168.1.158 on port 1883.1566194178: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194201: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194206: New connection from 192.168.1.158 on port 1883.[INFO] found mqtt on local database1566194207: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194230: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194239: New connection from 192.168.1.158 on port 1883.1566194239: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt').1566194264: Client hassmart_3key_8C3B64 has exceeded timeout, disconnecting.1566194269: New connection from 192.168.1.158 on port 1883.1566194269: Saving in-memory database to /data/mosquitto.db.1566194269: New client connected from 192.168.1.158 as hassmart_3key_8C3B64 (p2, c1, k15, u'mqtt')
发表于 2019-8-19 14:06:27 | 显示全部楼层
@囧大,老板,打钱
建议楼主,论坛里有刷esphome固件的教程,接入会更方便
流水无味
灌水之王
发表于 2019-8-19 15:43:49 | 显示全部楼层
wifi 环境好么
HA新版本会有错误警告(多余参数无视没关系)
我没碰到断开问题
 楼主| 发表于 2019-8-19 16:09:18 | 显示全部楼层
xieahui 发表于 2019-8-19 15:43
wifi 环境好么
我没碰到断开问题 ...
其他东西没碰到 掉线的
发表于 2019-8-19 18:16:12 | 显示全部楼层
怀疑是wifi信号不好,加强信号再试试。
 楼主| 发表于 2019-8-19 19:20:59 | 显示全部楼层
我用的unifi的,不知道论坛其他人用过没。
信号已经加强到最大了……我换个AP试试
还有可能是其他问题吗
发表于 2019-8-20 09:10:31 | 显示全部楼层
信号问题  先把开关拆下来 在路由 AP附近 测试完再装回去
或者手机app看一下开关位置的信号到底如何
 楼主| 发表于 2019-8-20 11:19:28 | 显示全部楼层
谢谢各位的帮忙,我把MQTT从服务器上转出来放到树莓派上就好了。
我服务器上跑的东西有点多,黑群晖,爬虫,HA,windows。可能性能不太够了
GMT+8, 2025-12-23 22:49 , Processed in 0.055684 second(s), 5 queries , MemCached On.
