楼主: c1pher_小愚
[进阶教程] homebridge homeassistant 配置萤石C6H摄像头
发表于 2020-4-1 00:38:37 | 显示全部楼层
发表于 2020-9-29 20:00:34 | 显示全部楼层
萤石C6H很好吗
发表于 2020-10-10 22:47:55 | 显示全部楼层
请教一下,按教程配置了一下,HA配置文件报错 Invalid config for [camera.ffmpeg]: [ffmpeg_bin] is an invalid option for [camera.ffmpeg]. Check: camera.ffmpeg->ffmpeg_bin. (See ?, line ?).
配置文件里面的内容如下:
ffmpeg:
    ffmpeg_bin: usr/bin/ffmpeg
camera:
  - platform: ffmpeg
    input: -rtsp_transport tcp -i rtsp://admin:[email protected]:554/h264/ch1/main/av_stream
    ffmpeg_bin: /usr/bin/ffmpeg
    extra_arguments: -pred 1 -q:v 2 -s 1280x720
我的ffmpeg是在/usr/bin/ffmpeg,单独执行本地命令正常。
root@aml:/usr/bin# ffmpeg
ffmpeg version 3.4.8-0ubuntu0.2 Copyright (c) 2000-2020 the FFmpeg developers
  built with gcc 7 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
  configuration: --prefix=/usr --extra-version=0ubuntu0.2 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
发表于 2021-5-10 19:53:46 | 显示全部楼层
厉害了,学习学习
发表于 2021-5-12 19:09:16 | 显示全部楼层
11111111111
发表于 2021-6-1 04:32:37 | 显示全部楼层
请问在homeassistant 中如何安装ffmpeg
发表于 2022-4-22 15:28:21 | 显示全部楼层
楼主 现在加入HA成功了 ,要怎么样才可以接入homekit呢
发表于 2022-5-14 13:38:45 | 显示全部楼层
kevin 发表于 2020-10-10 22:47
**** 作者被禁止或删除 内容自动屏蔽 ****
朋友,我和你一样,你解决了吗?
发表于 2022-5-14 13:40:08 | 显示全部楼层
请教一下,按教程配置了一下,HA配置文件报错 Invalid config for [camera.ffmpeg]: [ffmpeg_bin] is an invalid option for [camera.ffmpeg]. Check: camera.ffmpeg->ffmpeg_bin. (See ?, line ?).请教大神们,这个报错到底是啥问题呢
 楼主| 发表于 2022-5-23 15:07:33 | 显示全部楼层
lichao 发表于 2022-5-14 13:40
请教一下,按教程配置了一下,HA配置文件报错 Invalid config for [camera.ffmpeg]: [ffmpeg_bin] is an in ...
我已经没在用这种方式了,你只能自己查找解决了
GMT+8, 2026-1-14 13:02 , Processed in 0.265073 second(s), 17 queries , MemCached On.
