查看: 6205|回复: 7
[技术探讨] [已解决]asuswrt的devicetracker又故障了...
发表于 2019-8-2 21:49:53 | 显示全部楼层 |阅读模式
重启HA后短暂正常,大概1分钟左右失效,所有设备状态为 nothome
故障点HA log:
2019-08-02 21:19:04 ERROR (MainThread) [aioasuswrt.connection] Host timeout.
2019-08-02 21:19:09 ERROR (SyncWorker_9) [custom_components.asuswrt2.sensor] OSError: [Errno 32] Broken pipe
2019-08-02 21:19:14 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-02 21:19:19 WARNING (MainThread) [homeassistant.components.sensor] Updating asuswrt sensor took longer than the scheduled update interval 0:00:30
2019-08-02 21:19:24 ERROR (SyncWorker_5) [miio.device] Unable to discover a device at address 192.168.50.223
2019-08-02 21:19:24 ERROR (SyncWorker_5) [custom_components.xiaomi_cooker] Got exception while fetching the state: Unable to discover the device 192.168.50.223
2019-08-02 21:19:26 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-02 21:19:29 ERROR (SyncWorker_11) [custom_components.meizu_hygrothermo.sensor] Unexpected error: [Errno 111] Connection refused
2019-08-02 21:19:39 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-02 21:19:50 WARNING (MainThread) [homeassistant.components.sensor] Updating asuswrt sensor took longer than the scheduled update interval 0:00:30
2019-08-02 21:19:52 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-02 21:19:55 ERROR (SyncWorker_0) [miio.device] Unable to discover a device at address 192.168.50.223
2019-08-02 21:19:55 ERROR (SyncWorker_0) [custom_components.xiaomi_cooker] Got exception while fetching the state: Unable to discover the device 192.168.50.223
2019-08-02 21:20:04 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-02 21:20:10 ERROR (SyncWorker_6) [custom_components.asuswrt2.sensor] OSError: [Errno 32] Broken pipe
2019-08-02 21:20:17 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-08-02 21:20:20 WARNING (MainThread) [homeassistant.components.sensor] Updating asuswrt sensor took longer than the scheduled update interval 0:00:30
2019-08-02 21:20:25 ERROR (SyncWorker_13) [miio.device] Unable to discover a device at address 192.168.50.223
2019-08-02 21:20:25 ERROR (SyncWorker_13) [custom_components.xiaomi_cooker] Got exception while fetching the state: Unable to discover the device 192.168.50.223
路由log:
Aug  2 21:35:46 login[27480]: root login on 'pts/0'
Aug  2 21:36:09 rss-redir[15237]: server recv: Connection reset by peer
Aug  2 21:36:26 login[27921]: root login on 'pts/1'
Aug  2 21:36:26 login[27931]: root login on 'pts/2'
Aug  2 21:36:28 login[27935]: root login on 'pts/1'
Aug  2 21:36:28 login[27950]: root login on 'pts/2'
Aug  2 21:36:29 login[27954]: root login on 'pts/1'
Aug  2 21:36:29 login[27963]: root login on 'pts/2'
Aug  2 21:36:29 login[27978]: root login on 'pts/1'
Aug  2 21:36:30 login[27982]: root login on 'pts/2'
Aug  2 21:36:48 login[28055]: root login on 'pts/1'
Aug  2 21:37:57 login[28379]: root login on 'pts/6'
Aug  2 21:37:59 dnsmasq-dhcp[15693]: DHCPREQUEST(br0) 192.168.50.221 00:xx:xx:xx:xx:16
Aug  2 21:37:59 dnsmasq-dhcp[15693]: DHCPACK(br0) 192.168.50.221 00:xx:xx:xx:xx:16 Home-Assistant
Aug  2 21:41:46 miniupnpd[14013]: removed 14 unused rules
搜了一圈 没结果...前几天是正常的  最近发现回家相关自动化失效 目前排查到这里
0813更新:asuswrt 配置增加  mode: router 即可
发表于 2019-8-3 09:47:12 | 显示全部楼层
asuswrt目前的设备追踪比之前版本的好多了,但我依然没有为此做自动化,因为依然会有不稳定情况发生。
有时候也会有设备断网不显示not home状态发生。
作为自动化,需要有基本稳定的条件,如果不稳定性事件经常发生,那就不适合做自动化,另外手机关机或者退出wifi也算离家,所以个人觉得目前的asuswrt device tracker还不太适合做自动化。
我一位兄弟用小米手环蓝牙追踪都比这个稳定。
 楼主| 发表于 2019-8-3 14:21:20 | 显示全部楼层
有时 ...
我这个蓝牙驱动还有问题
发表于 2019-8-3 16:42:46 | 显示全部楼层
ghostist 发表于 2019-8-3 14:21
我这个蓝牙驱动还有问题
我不用蓝牙追踪,我就直接人体传感器自动化
发表于 2019-8-3 17:12:06 | 显示全部楼层
请问怎么判断?
发表于 2019-8-8 17:22:23 | 显示全部楼层
不用devicetracker,直接asuswrt比插件的稳定,不过都是无线设备,上线提示很快,离线有延迟
 楼主| 发表于 2019-8-9 09:38:00 | 显示全部楼层
sweetstzw 发表于 2019-8-8 17:22
不用devicetracker,直接asuswrt比插件的稳定,不过都是无线设备,上线提示很快,离线有延迟 ...
直接asuswrt  有devicetracker的功能吗?
发表于 2019-8-9 13:33:13 | 显示全部楼层
有的,我是K2P刷的Pandavan,用插件一直不起效果
GMT+8, 2025-11-8 09:16 , Processed in 0.068076 second(s), 5 queries , MemCached On.
