查看: 6221|回复: 1
[求助] homeassistant 更新0.96.5报错,要怎么解决
发表于 2019-8-2 19:40:04 | 显示全部楼层 |阅读模式
19-08-02 11:34:08 INFO (SyncWorker_19) [hassio.docker.interface] Update image homeassistant/qemuarm-64-homeassistant:0.95.4 to homeassistant/qemuarm-64-homeassistant:0.96.519-08-02 11:34:08 INFO (SyncWorker_19) [hassio.docker.interface] Pull image homeassistant/qemuarm-64-homeassistant tag 0.96.5.19-08-02 11:34:35 ERROR (SyncWorker_19) [hassio.docker.interface] Can't install homeassistant/qemuarm-64-homeassistant:0.96.5 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/ ... t/manifests/0.96.5: Get https://auth.docker.io/token?sco ... registry.docker.io: net/http: TLS handshake timeout").19-08-02 11:34:35 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
发表于 2019-8-2 20:36:48 | 显示全部楼层
我是更新完了,无法进入页面,显示404
GMT+8, 2025-12-24 00:52 , Processed in 0.080834 second(s), 9 queries , MemCached On.
