查看: 25091|回复: 37
[插件集成] (代码S大已合并)修改syssi大神米家空调伴侣插件适配HA 0.96
发表于 2019-8-1 22:11:34 | 显示全部楼层 |阅读模式
8/2号更新,提交的PR,S大已合并,可以到https://github.com/syssi/xiaomi_airconditioningcompanion 直接下载了
HA 0.96更新,Climate组件改动很大,导致syssi大神的空调伴侣已不能再用。
S大的repo已经有人提交了issue https://github.com/syssi/xiaomi_airconditioningcompanion/issues/67
但是啥时候更新,目前还是未知数(S大感觉很忙)
今天 @neroxps 建议我提交PR给S大。
但是由于对Python不是很熟,代码写的可能不符合规范。
这里就分享出来,论坛的Python大神可以给个参考哇?。
也请各位有空调伴侣的帮忙测试一下是否有问题。
如果没有问题的话,我就直接提交PR了。
很少发帖,感觉很乱,见谅。
以下是关键代码修改部分:
  @asyncio.coroutine
    def async_update(self):
        """Update the state of this climate device."""
        from miio import DeviceException
        try:
            state = yield from self.hass.async_add_job(self._device.status)
            _LOGGER.debug("Got new state: %s", state)
            self._available = True
            self._state_attrs.update({
                ATTR_AIR_CONDITION_MODEL: state.air_condition_model.hex(),
                ATTR_LOAD_POWER: state.load_power,
                ATTR_TEMPERATURE: state.target_temperature,
                ATTR_SWING_MODE: state.swing_mode.name.lower(),
                ATTR_FAN_MODE: state.fan_speed.name.lower(),
                ATTR_HVAC_MODE: state.mode.name.lower() if self._state else "off",
                ATTR_LED: state.led,
            """新增变量(属性)_last_on_operation从miio获取的空调的操作(heat, cool, fan_only, dry)"""
            self._last_on_operation = OperationMode[state.mode.name].value
           """miio获取到空调处于关机状态时, hvac_mode值为off"""
            if state.power == 'off':
                self._hvac_mode = HVAC_MODE_OFF
                self._state = False
           """开机状态时, hvac_mode值等于_last_on_operation"""
            else:
                self._hvac_mode = self._last_on_operation
                self._state = True
            self._target_temperature = state.target_temperature
            self._fan_mode = state.fan_speed
            self._swing_mode = state.swing_mode
            if self._air_condition_model is None:
                self._air_condition_model = state.air_condition_model.hex()
        except DeviceException as ex:
            self._available = False
            _LOGGER.error("Got exception while fetching the state: %s", ex)
@asyncio.coroutine
    def async_set_hvac_mode(self, hvac_mode):
        """Set new target hvac mode."""
        if hvac_mode == OperationMode.Off.value:
            result = yield from self._try_command(
                "Turning the miio device off failed.", self._device.off)
            if result:
                self._state = False
        else:
            self._hvac_mode = OperationMode(hvac_mode).value
            self._state = True
            yield from self._send_configuration()
   @asyncio.coroutine
    def _send_configuration(self):
        from miio.airconditioningcompanion import \
            Power, Led, OperationMode as MiioOperationMode
    """确保不将hvac_mode为off状态时,直接传给miio,否者会报错"""
        if self._air_condition_model is not None:
                "Sending new air conditioner configuration failed.",
                self._device.send_configuration,
                self._air_condition_model,
                Power(int(self._state)),
                MiioOperationMode[OperationMode(self._hvac_mode).name] if self._state else MiioOperationMode[OperationMode(self._last_on_operation).name],
                int(self._target_temperature),
                self._fan_mode,
                self._swing_mode,
                Led.Off,
        else:
            _LOGGER.error('Model number of the air condition unknown. '
                          'Configuration cannot be sent.')
附件是完整的修改版
climate.py
17.69 KB, 下载次数: 55
参与人数 6金钱 +83 收起 理由
neroxps + 20 辛苦了
ddkens + 5 好像不能通过功率来反馈空调开关状态?.
咸味土豆 + 20 大神666,风扇的有没有可能更新一下。.
uavana + 8 论坛有你更精彩!
+ 20 虽然用不到,但是非常感谢~
jyz_0501 + 10 虽然用不到,但是非常感谢~
发表于 2019-8-1 22:22:45 | 显示全部楼层
强烈支持
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-8-1 23:04:19 | 显示全部楼层
火钳刘明~
wqqs 手机认证
活跃会员
发表于 2019-8-1 23:11:01 | 显示全部楼层
正需要这东西
发表于 2019-8-1 23:13:22 | 显示全部楼层
只有米家那个60几块的便宜货,还在期待大佬开发。
发表于 2019-8-1 23:40:55 | 显示全部楼层
感谢奉献!
发表于 2019-8-1 23:44:21 | 显示全部楼层
支持一下,升级96指日可待,谢谢
流水无味
灌水之王
发表于 2019-8-2 07:20:57 | 显示全部楼层
关注下空调这一块
发表于 2019-8-2 08:15:41 | 显示全部楼层
亲测可用
发表于 2019-8-2 09:18:47 | 显示全部楼层
支持啊,每次ha升级都改动 这点很烦
GMT+8, 2025-12-26 12:55 , Processed in 0.305857 second(s), 10 queries , MemCached On.
