楼主: se7en
[进阶教程] led灯带接入hass,homekit
发表于 2018-1-1 02:25:24 | 显示全部楼层
学习。。。。。。。。。。。。。。。。
发表于 2018-1-2 18:50:06 | 显示全部楼层
请教楼主大人!按照你的指示我把库文件有安装的!验证一直报错。。。能指导下吗?
Arduino:1.6.12 (Windows 8.1), 开发板:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 2M (1M SPIFFS), ck, Disabled, None"
In file included from C:\Users\瀹嬫稕\Documents\Arduino\libraries\LED\LED.ino:16:0:
C:\Users\宋涛\Documents\Arduino\libraries\FastLED-master/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.005
#    pragma message "FastLED version 3.001.005"
In file included from C:\Users\宋涛\Documents\Arduino\libraries\FastLED-master/FastLED.h:65:0,
C:\Users\宋涛\Documents\Arduino\libraries\FastLED-master/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
#      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
C:\Users\瀹嬫稕\Documents\Arduino\libraries\LED\LED.ino: In function 'void setup()':
LED:144: error: 'setupStripedPalette' was not declared in this scope
LED:151: error: 'setup_wifi' was not declared in this scope
LED:154: error: 'callback' was not declared in this scope
C:\Users\瀹嬫稕\Documents\Arduino\libraries\LED\LED.ino: In function 'void loop()':
LED:270: error: 'reconnect' was not declared in this scope
LED:319: error: 'addGlitter' was not declared in this scope
LED:325: error: 'addGlitterColor' was not declared in this scope
LED:456: error: 'fadeall' was not declared in this scope
LED:467: error: 'fadeall' was not declared in this scope
LED:474: error: 'Fire2012WithPalette' was not declared in this scope
"ubSubClient.h" 对应多个库
已使用: C:\Users\宋涛\Documents\Arduino\libraries\PubSubClient
未使用:C:\Users\宋涛\Documents\Arduino\libraries\pubsubclient-master
exit status 1
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
发表于 2018-1-7 21:18:09 | 显示全部楼层
厉害,学习了
发表于 2018-1-7 22:06:53 | 显示全部楼层
谢谢大神,分享
发表于 2018-2-6 16:50:32 | 显示全部楼层
谢谢分享
发表于 2018-2-6 23:32:43 | 显示全部楼层
谢谢楼主的无私奉献
发表于 2018-2-7 00:03:22 | 显示全部楼层
谢谢楼主无私的分享
发表于 2018-2-21 11:35:24 | 显示全部楼层
同关注  学习了
Yang
发表于 2018-3-2 10:50:05 | 显示全部楼层
发表于 2018-3-8 11:03:48 | 显示全部楼层
弱弱问一下   这个稳定性怎么样
GMT+8, 2025-9-15 05:06 , Processed in 0.128143 second(s), 11 queries , MemCached On.
