楼主: se7en
[进阶教程] led灯带接入hass,homekit
发表于 2017-9-12 22:45:39 | 显示全部楼层
太漂亮了,留着备用
发表于 2017-9-13 07:51:32 来自手机 | 显示全部楼层
发表于 2017-9-13 10:39:07 | 显示全部楼层
mark,这个灯很有感觉
发表于 2017-9-16 00:05:49 | 显示全部楼层
大神,纯小白第一次接触,想问下,怎么烧录这个ino固件啊?要在ide里面做什么吗
发表于 2017-9-16 11:22:13 | 显示全部楼层
谢谢分享
发表于 2017-9-16 11:58:36 | 显示全部楼层
homekit怎么添加配件呀
发表于 2017-9-17 11:16:48 | 显示全部楼层
您好,全部都弄完后,控制台按灯按钮会自动关闭,灯带没被控制,日志如下,求教
2017-09-17 14:11:06 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-09-17 14:11:08 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform yr is taking over 10 seconds.
2017-09-17 14:11:08 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes:
发表于 2017-9-17 11:26:15 | 显示全部楼层
2017-09-17 14:23:09 ERROR (MainThread) [hbmqtt.broker] Broker startup failed: [Errno 98] error while attempting to bind on address ('0.0.0.0', 1883): address already in use
2017-09-17 14:23:09 ERROR (MainThread) [homeassistant.components.mqtt.server] Error initializing MQTT server
  File "/usr/lib/python3.5/asyncio/base_events.py", line 1042, in create_server
    sock.bind(sa)
OSError: [Errno 98] Address already in use
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/hbmqtt/broker.py", line 270, in start
    loop=self._loop)
  File "/usr/lib/python3.5/asyncio/streams.py", line 113, in start_server
    return (yield from loop.create_server(factory, host, port, **kwds))
  File "/usr/lib/python3.5/asyncio/base_events.py", line 1046, in create_server
    % (sa, err.strerror.lower()))
OSError: [Errno 98] error while attempting to bind on address ('0.0.0.0', 1883): address already in use
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/mqtt/server.py", line 48, in async_start
    yield from broker.start()
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/hbmqtt/broker.py", line 291, in start
    raise BrokerException("Broker instance can't be started: %s" % e)
hbmqtt.broker.BrokerException: Broker instance can't be started: [Errno 98] error while attempting to bind on address ('0.0.0.0', 1883): address already in use
2017-09-17 14:23:09 ERROR (MainThread) [homeassistant.components.mqtt] Unable to start MQTT broker.
2017-09-17 14:23:09 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: Component failed to initialize.
2017-09-17 14:23:09 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of light.mqtt. Setup failed for dependencies: mqtt
2017-09-17 14:23:09 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform light.mqtt: Could not setup all dependencies.
重装mqtt后 变这样了
发表于 2017-9-19 16:16:10 | 显示全部楼层
正在做,查看下
发表于 2017-9-25 17:53:43 | 显示全部楼层
谢谢楼主分享,看看。
GMT+8, 2025-9-13 03:27 , Processed in 0.148938 second(s), 12 queries , MemCached On.
