查看: 7506|回复: 4
[求助] 运行Homebridge出现的Error: dns service error: name conflict
发表于 2017-8-4 21:41:07 | 显示全部楼层 |阅读模式
这样算是成功安装hoembridge了么?
在iOS系统上配对的PIN码不是123-45-678
而是最开始的蹦出来的031-45-154
下面的错误说的是什么?DNS?名字?
烦请前辈们指点。
pi@hassbian:~/.homebridge $ homebridge
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... ServiceRegister>
[2017-8-4 13:34:30] Loaded plugin: homebridge-broadlink-rm
[2017-8-4 13:34:30] Registering platform 'homebridge-broadlink-rm.BroadlinkRM'
[2017-8-4 13:34:30] ---
[2017-8-4 13:34:31] Loaded plugin: homebridge-homeassistant
[2017-8-4 13:34:31] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2017-8-4 13:34:31] ---
[2017-8-4 13:34:31] Loaded config.json with 0 accessories and 1 platforms.
[2017-8-4 13:34:31] Loading 1 platforms...
[2017-8-4 13:34:31] [HomeAssistant] Initializing HomeAssistant platform...
[2017-8-4 13:34:31] [HomeAssistant] Fetching HomeAssistant devices.
[2017-8-4 13:34:31] [HomeAssistant] Received event: ping
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    │ 123-45-678 │
/usr/lib/node_modules/hap-nodejs/node_modules/mdns/lib/advertisement.js:56
  dns_sd.DNSServiceRegister(self.serviceRef, flags, ifaceIdx, name,
    at new Advertisement (/usr/lib/node_modules/hap-nodejs/node_modules/mdns/lib/advertisement.js:56:10)
    at Object.create [as createAdvertisement] (/usr/lib/node_modules/hap-nodejs/node_modules/mdns/lib/advertisement.js:64:10)
    at Advertiser.startAdvertising (/usr/lib/node_modules/hap-nodejs/lib/Advertiser.js:43:30)
    at Bridge.Accessory._onListening (/usr/lib/node_modules/hap-nodejs/lib/Accessory.js:532:20)
    at emitOne (events.js:115:13)
    at HAPServer.emit (events.js:210:7)
    at HAPServer._onListening (/usr/lib/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
    at EventedHTTPServer.emit (events.js:210:7)
    at EventedHTTPServer.<anonymous> (/usr/lib/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
 楼主| 发表于 2017-8-5 11:59:05 | 显示全部楼层
虚惊一场哈哈
Errors on startup
The following errors are experienced when starting Homebridge and can be safely ignored. The cost of removing the issue at the core of the errors isn't worth the effort.
*** WARNING *** For more information see http://0pointerde/avahi-compat?s=libdns_sd&e=nodejs
*** WARNING *** For more information see http://0pointerde/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister
发表于 2017-8-18 20:49:50 | 显示全部楼层
我也遇到这个问题了,你怎么解决的?
发表于 2017-8-21 15:09:55 | 显示全部楼层
今天新装1.02也是这样了,不知道什么原因哈
发表于 2017-9-11 01:58:08 | 显示全部楼层
你解决了吗?我也遇到这样的问题,怎么办的?
GMT+8, 2025-12-25 15:51 , Processed in 0.440738 second(s), 10 queries , MemCached On.
