查看: 5823|回复: 2
[求助] 求大神解答?????
发表于 2019-7-23 21:00:29 | 显示全部楼层 |阅读模式
# 1. 是否将系统源切换为中科大(USTC)源: 是
# 2. 是否将用户添加至 Docker 用户组:   是,添加用户为 pi
# 3. 是否将 Docker 源切换至国内源:     是,切换源选择:七牛云
# 4. 您的设备类型为:                   raspberrypi3
# 5. 您的 hassio 数据路径为:           /usr/share/hassio
请确认以上信息,继续请按任意键,如需修改请输入 Ctrl+C 结束任务重新执行脚本。
[info]: 切换系统网络源.....
备份系统源文件为 /etc/apt/sources.list.bak
Ign:1 http://mirrors.aliyun.com/debian stretch InRelease
Hit:2 http://mirrors.ustc.edu.cn/raspbian/raspbian buster InRelease
Get:3 http://mirrors.aliyun.com/debian stretch Release [118 kB]
Get:4 http://mirrors.aliyun.com/debian stretch Release.gpg [2,434 B]
Hit:5 http://mirrors.ustc.edu.cn/archive.raspberrypi.org/debian buster InRelease
Hit:6 http://mirrors.ustc.edu.cn/raspbian/raspbian stretch InRelease
Hit:7 https://download.docker.com/linux/debian buster InRelease
Ign:4 http://mirrors.aliyun.com/debian stretch Release.gpg
Reading package lists... Done
W: GPG error: http://mirrors.aliyun.com/debian stretch Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7638D0442B90D010 NO_PUBKEY 04EE7237B7D453EC NO_PUBKEY EF0F382A1A7B6500
E: The repository 'http://mirrors.aliyun.com/debian stretch Release' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Skipping acquire of configured file 'ui/binary-armhf/Packages' as repository 'http://mirrors.ustc.edu.cn/raspbian/raspbian stretch InRelease' doesn't have the component 'ui' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'ui/i18n/Translation-en' as repository 'http://mirrors.ustc.edu.cn/raspbian/raspbian stretch InRelease' doesn't have the component 'ui' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'ui/i18n/Translation-en_GB' as repository 'http://mirrors.ustc.edu.cn/raspbian/raspbian stretch InRelease' doesn't have the component 'ui' (component misspelt in sources.list?)
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
[ERROR]: 系统源切换错误,请检查网络连接是否正常,脚本退出
root@raspberrypi:/home/pi#
电信网络!!!!!!!!!!!!!!!一切正常!!!!!
Jeff
活跃会员
发表于 2019-7-24 07:36:48 | 显示全部楼层
应该是不支持debian 10,最大支持到stretch
Jeff
发表于 2019-7-24 16:22:16 | 显示全部楼层
看了下 get.docker.com 已经更新了 10 的源,但是不知道为什么树莓派有问题。
GMT+8, 2025-12-24 02:22 , Processed in 1.195546 second(s), 5 queries , MemCached On.
