楼主: 咸味土豆
Docker环境安装homebridge,解决HA的Homekit不能接入摄像头问题。
eric 手机认证
卓越贡献
发表于 2019-8-6 13:38:17 | 显示全部楼层
咸味土豆 发表于 2019-7-29 09:40
没怎么玩,等着大佬发帖子好捡现成的,
我现在搞了个笔记本,然后debian+docker,五代i7的移动处理器, ...
我依然还是pve 虚拟机debian搞。目前单独一个门口摄像头,在外网打开秒进实时,不卡。就是声音不会搞!
发表于 2019-11-9 12:08:34 | 显示全部楼层
接入了一个tplink的,ha里面正常显示,可是hb接入hk,怎么都显示不了画面
11/9/2019, 12:06:37 PM] [Camera-ffmpeg] Snapshot from camera at 480x270
[11/9/2019, 12:06:37 PM] [Camera-ffmpeg] An error occurs while making snapshot request
[11/9/2019, 12:06:47 PM] [Camera-ffmpeg] Snapshot from camera at 480x270
[11/9/2019, 12:06:47 PM] [Camera-ffmpeg] An error occurs while making snapshot request
[11/9/2019, 12:06:52 PM] [Camera-ffmpeg] Start streaming video from camera with 1280x720@299kBit
[11/9/2019, 12:06:52 PM] [Camera-ffmpeg] An error occurs while making stream request
[11/9/2019, 12:06:52 PM] [Camera-ffmpeg] ERROR: FFmpeg exited with code -2
发表于 2019-11-9 14:16:12 | 显示全部楼层
可否帮助看看这个错误是什么原因呢?搜了半天也找不到,国外也有人遇到,但是提问也都没看到有人能回答解决。。。
插件也都安装成功的,实在是不明白了,ha里面都能正常显示,也能接入群晖摄像头,vlc也能正常看
    "bridge": {
        "name": "Homebridge",
        "username": "0E5:BC:AB:58:C6",
        "port": 51452,
        "pin": "031-55-154"
    "description": "This is an example configuration file. You can use this as a template for creating your own configuration file containing devices you actually own.",
    "accessories": [],
    "platforms": [
            "name": "Camera-ffmpeg",
            "cameras": [
                    "name": "camera",
                    "videoConfig": {
                        "source": "-rtsp_transport tcp -i rtsp://admin:[email protected]/stream1",
                        "stillImageSource": "-i http://faster_still_image_grab_url/this_is_optional.jpg",
                        "maxStreams": 2,
                        "maxWidth": 1280,
                        "maxHeight": 720,
                        "maxFPS": 15,
                        "maxBitrate": 300,
                        "vcodec": "h264",
                        "packetSize": 188,
                        "audio": false,
                        "debug": false
            "platform": "Camera-ffmpeg"
发表于 2019-11-12 21:31:40 | 显示全部楼层
估计就是解码的问题,我重新安装了一个hb,然后重新安装ffmpeg,tplink的可以正常接入hk了,但是foscam变成了错误1,唉。。。
发表于 2019-12-3 19:41:41 | 显示全部楼层
12512310 发表于 2019-11-12 21:31
估计就是解码的问题,我重新安装了一个hb,然后重新安装ffmpeg,tplink的可以正常接入hk了,但是foscam变成 ...
你的解决了没?我的也是这个问题,蛋疼。。。
发表于 2020-1-27 16:57:43 | 显示全部楼层
小白一枚,不懂
发表于 2020-1-28 19:48:32 | 显示全部楼层
好东西,先收藏着.
发表于 2020-5-10 00:42:47 | 显示全部楼层
在管理页面升级UI了就进不去了,求问有办法吗???
hugo
发表于 2020-5-29 01:01:52 | 显示全部楼层
要ffmpeg适配,可以自己去ffmpeg看看编译个,没声音一个是编译的问题,一个是参数的问题,要支持声音要加个参数记得,现在也不用纠结ha摄像头问题了,最新版本已经可以完美支持ha摄像头进入homekit了
发表于 2020-6-11 17:28:54 | 显示全部楼层
啊 我群晖docker安装ha一直失败  太痛苦了
GMT+8, 2026-1-15 05:05 , Processed in 1.460166 second(s), 11 queries , MemCached On.
