查看: 11118|回复: 6
[求助] hassio打不开了
发表于 2019-7-23 03:33:16 | 显示全部楼层 |阅读模式
1.png 各位好,刚刚开始学习hass。这个配置页面和地图自从更新96之后就变成灰色不能用了,我也没有在意,今天在configuration.yaml加上ping传感器之后重启了HA,结果网页就上不去了,但是通过SSH和SMB还可以登陆上去,我就把加的都删了,还是不行,ha的log如下:
2019-07-23 03:26:09 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: Invalid time zone passed in. Valid options can be found here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones for dictionary value @ data['time_zone']. Got 'Asia/Shanghai n'. (See /config/configuration.yaml, line 2).
2019-07-23 03:26:09 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/core.py", line 1127, in async_call
    raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service persistent_notification/create
向各位求助,谢谢~
流水无味
灌水之王
发表于 2019-7-23 07:31:04 | 显示全部楼层
Asia/Shanghai n?
是不是 shanghai 后面多了个N? 估计手误
发表于 2019-7-23 07:37:02 | 显示全部楼层
xieahui 发表于 2019-7-23 07:31
Asia/Shanghai n?
哈哈哈,报错
发表于 2019-7-23 08:35:34 | 显示全部楼层
0.96不是加入了,高级模式吗?是不是要开启高级模式,我还停在0.95
发表于 2019-7-23 08:51:00 | 显示全部楼层
2楼正解
发表于 2019-7-23 17:52:11 | 显示全部楼层
珠三角地区为何不用香港时区
 楼主| 发表于 2019-7-24 02:16:42 | 显示全部楼层
果然是手抽打多了个N,现在可以进系统了,但是那个地图页面还有编辑器还是灰色的不可用状态,编辑器已禁用,因为配置存储于 configuration.yam
2019-07-23 14:48:23 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=77 from 2019-07-23 04:25:37.910960)2019-07-23 14:49:35 WARNING (zeroconf-ServiceBrowser__axis-video._tcp.local.) [zeroconf] Exception occurred:Traceback (most recent call last):  File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2245, in send    bytes_sent = s.sendto(packet, 0, (addr, port))PermissionError: [Errno 1] Operation not permitted2019-07-24 02:00:45 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /homeassistant/restart request
GMT+8, 2025-12-24 00:52 , Processed in 0.171725 second(s), 5 queries , MemCached On.
