查看: 4011|回复: 4
[技术探讨] 我不服,这是肿么啦!device tracker一直错误
发表于 2019-7-17 00:45:39 | 显示全部楼层 |阅读模式
路由器是华硕ac1900p,ha版本是0.95.4 配置device  tracker一直不ok,论坛里面的全部参照了,请大佬出来走两步,谢谢……
下面是错误代码:
Error during setup of component asuswrt
  File "/usr/src/homeassistant/homeassistant/setup.py", line 153, in _async_setup_component
    hass, processed_config)
  File "/usr/src/homeassistant/homeassistant/components/asuswrt/__init__.py", line 55, in async_setup
    await api.connection.async_connect()
  File "/usr/local/lib/python3.7/site-packages/aioasuswrt/connection.py", line 72, in async_connect
    self._client = await asyncssh.connect(self._host, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/asyncssh/misc.py", line 182, in __await__
    return (yield from self._coro)
  File "/usr/local/lib/python3.7/site-packages/asyncssh/connection.py", line 5451, in connect
    conn, _ = yield from create_connection(None, host, port, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/asyncssh/connection.py", line 5100, in create_connection
    local_addr=local_addr)
  File "uvloop/loop.pyx", line 1904, in create_connection
  File "uvloop/loop.pyx", line 1883, in uvloop.loop.Loop.create_connection
ConnectionRefusedError: [Errno 111] Connection refused
发表于 2019-7-17 08:59:11 | 显示全部楼层
昨晚刚从群里大佬那边得到解决方案,应该是内置的内网扫描,离线稍有延迟,上线倒是还挺快,在配置文件中添加如下配置:
device_tracker:
  - platform: nmap_tracker
    hosts:
      - xxx.xxx.xxx.xxx  # 需追踪的ip
      - xxx.xxx.xxx.xxxx
 楼主| 发表于 2019-7-17 17:29:01 | 显示全部楼层
lxiaoyang 发表于 2019-7-17 08:59
昨晚刚从群里大佬那边得到解决方案,应该是内置的内网扫描,离线稍有延迟,上线倒是还挺快,在配置文件中添 ...
你这个是nmap扫描?
发表于 2019-7-17 17:52:26 | 显示全部楼层
scboy 发表于 2019-7-17 17:29
你这个是nmap扫描?
是的   可以用
 楼主| 发表于 2019-7-18 14:57:35 | 显示全部楼层
谢谢老哥,确实可以使用,就是不是实时的。延迟有点大,nmap略知一点丁点。晚上看看能配置扫描间歇不
GMT+8, 2026-1-1 14:07 , Processed in 0.138467 second(s), 9 queries , MemCached On.
