查看: 6506|回复: 3
[技术探讨] smartIR控制空调一直无法开启
发表于 2019-7-12 17:13:56 | 显示全部楼层 |阅读模式
HA:0.92.2smartIR:
博联broadlink pro
遇到的问题:1、同时配置了空调、风扇、电视, 风扇和电视控制都没问题,打开关闭,调风速等设置都没问题。 2、唯独空调打开有问题,如果直接打开空调会报下面的错误。3、空调可以直接调成制冷、制热、自动等模式,风速调整也都没问题,唯独就是打开空调控制不了。不知道是什么原因, 还请哪位大神多多指教。
这是我得目录结构:
smartir/
├── climate.py
├── codes
│   ├── climate
│   │   └── 1181.json
│   ├── fan
│   │   └── 1020.json
│   └── media_player
│       └── 1040.json
├── controller.py
├── fan.py
├── __init__.py
├── manifest.json
├── media_player.py
├── __pycache__
│   ├── climate.cpython-35.pyc
│   ├── controller.cpython-35.pyc
│   ├── fan.cpython-35.pyc
│   ├── __init__.cpython-35.pyc
│   └── media_player.cpython-35.pyc
└── services.yaml
5 directories, 15 files
这是配置文件信息:
空调的代码
- platform: smartir
  unique_id: keting_ac
  device_code: 1181
  controller_data: 192.168.88.166
  temperature_sensor: sensor.temperature
  humidity_sensor: sensor.humidity
风扇的代码:
- platform: smartir
  unique_id: kayee_fan
  device_code: 1020
电视机的代码:
- platform: smartir
  unique_id: lg_tv
  device_code: 1040
错误信息:
'low'
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
    connection.context(msg))
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 1138, in async_call
    self._execute_service(handler, service_call))
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 1160, in _execute_service
    await handler.func(service_call)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py", line 194, in handle_service
    required_features
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/service.py", line 316, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/service.py", line 337, in _handle_service_platform_call
    await getattr(entity, func)(**data)
  File "/home/pi/.homeassistant/custom_components/smartir/climate.py", line 313, in async_turn_on
    await self.async_set_operation_mode(self._last_on_operation)
  File "/home/pi/.homeassistant/custom_components/smartir/climate.py", line 295, in async_set_operation_mode
    await self.send_command()
  File "/home/pi/.homeassistant/custom_components/smartir/climate.py", line 327, in send_command
    command = self._commands[operation_mode][fan_mode][target_temperature]
KeyError: 'low'
调用服务 climate/turn_on 失败。 'low'
发表于 2019-7-17 14:20:04 | 显示全部楼层
貌似也碰到过这种问题,换个码库或自己录码试试。
我的好久没折腾了,今晚回去搞搞。
发表于 2019-7-17 14:38:45 | 显示全部楼层
学下一下打开空调的码录入试试
发表于 2019-7-30 16:49:02 | 显示全部楼层
学习一下~~~~~~~~~~~~~~~~~~
GMT+8, 2026-1-1 11:53 , Processed in 0.789833 second(s), 12 queries , MemCached On.
