群晖DSM安装Hassio(非虚拟机)此方法暂已弃用
发表于 2020-3-16 15:16:04 | 显示全部楼层
谢谢分享
发表于 2020-3-17 15:02:22 | 显示全部楼层
addlm 发表于 2020-3-15 23:19
我也是这个问题,刚才在github上查到了这个问题的解决办法,发在这里供大家看看:
核心原因是DSM群晖没有 ...
成功了,多谢大佬
发表于 2020-3-17 19:09:24 | 显示全部楼层
添加源,好像也没有hassio了
发表于 2020-3-18 11:39:42 | 显示全部楼层
核心原因是DSM群晖没有 ...
果然管用,感谢分享,终于好了。
发表于 2020-3-18 12:06:55 | 显示全部楼层
为啥群晖社群套件里找不到hass.io呢?咋安装?
发表于 2020-3-20 23:52:35 | 显示全部楼层
手动安装显示无法安装或者不支持当前版本
发表于 2020-3-21 11:50:29 | 显示全部楼层
麻烦大神帮忙看看  按照作者的方案安装的   无法正常运行,重新装过好多次了,感谢感谢
hassio_supervisor
date        stream        content
2020-03-21 03:41:12        stderr        20-03-21 03:41:12 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:41:12        stderr        20-03-21 03:41:12 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:41:12        stderr        20-03-21 03:41:12 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:41:01        stderr        20-03-21 03:41:01 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:40:31        stderr        20-03-21 03:40:31 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:40:31        stderr        20-03-21 03:40:31 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:40:31        stderr        20-03-21 03:40:31 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:40:20        stderr        20-03-21 03:40:20 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:39:50        stderr        20-03-21 03:39:50 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:39:50        stderr        20-03-21 03:39:50 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:39:50        stderr        20-03-21 03:39:50 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:39:39        stderr        20-03-21 03:39:39 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:39:09        stderr        20-03-21 03:39:09 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:39:09        stderr        20-03-21 03:39:09 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:39:09        stderr        20-03-21 03:39:09 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:38:58        stderr        20-03-21 03:38:58 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:38:28        stderr        20-03-21 03:38:28 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:38:28        stderr        20-03-21 03:38:28 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:38:28        stderr        20-03-21 03:38:28 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:38:17        stderr        20-03-21 03:38:17 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:37:47        stderr        20-03-21 03:37:47 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:37:47        stderr        20-03-21 03:37:47 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:37:47        stderr        20-03-21 03:37:47 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:37:36        stderr        20-03-21 03:37:36 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:37:06        stderr        20-03-21 03:37:06 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:37:06        stderr        20-03-21 03:37:06 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:37:06        stderr        20-03-21 03:37:06 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:36:55        stderr        20-03-21 03:36:55 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:36:25        stderr        20-03-21 03:36:25 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:36:25        stderr        20-03-21 03:36:25 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:36:25        stderr        20-03-21 03:36:25 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:36:14        stderr        20-03-21 03:36:14 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:35:44        stderr        20-03-21 03:35:44 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:35:44        stderr        20-03-21 03:35:44 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:35:44        stderr        20-03-21 03:35:44 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:35:34        stderr        20-03-21 03:35:34 INFO (MainThread) [supervisor.audio] Setup Audio plugin
2020-03-21 03:35:34        stderr        20-03-21 03:35:34 INFO (MainThread) [supervisor.audio] No Audio plugin Docker image homeassistant/amd64-hassio-audio found.
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/amd64-hassio-dns found.
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: set()
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.hostname] No hostname support on the host. Hostname functions have been disabled.
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.systemd] No systemd support on the host. Host control has been disabled.
2020-03-21 03:35:33        stderr        20-03-21 03:35:33 INFO (MainThread) [__main__] Setup Supervisor
2020-03-21 03:35:32        stderr        20-03-21 03:35:32 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
2020-03-21 03:35:32        stderr        20-03-21 03:35:32 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 209
2020-03-21 03:35:24        stderr        20-03-21 03:35:24 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, create new network
2020-03-21 03:35:24        stderr        20-03-21 03:35:24 INFO (MainThread) [__main__] Initialize Supervisor setup
2020-03-21 03:35:18        stdout        [services.d] done.
2020-03-21 03:35:18        stdout        [services.d] starting services
2020-03-21 03:35:18        stdout        [cont-init.d] done.
2020-03-21 03:35:18        stdout        [cont-init.d] udev.sh: exited 0.
2020-03-21 03:35:16        stderr        [03:35:16] INFO: Update udev informations
2020-03-21 03:35:15        stdout        [cont-init.d] udev.sh: executing...
2020-03-21 03:35:15        stdout        [cont-init.d] executing container initialization scripts...
2020-03-21 03:35:15        stdout        [fix-attrs.d] done.
2020-03-21 03:35:15        stdout        [fix-attrs.d] applying ownership & permissions fixes...
2020-03-21 03:35:15        stdout        [s6-init] ensuring user provided files have correct perms...exited 0.
2020-03-21 03:35:15        stdout        [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
发表于 2020-3-22 16:53:04 | 显示全部楼层
20-03-22 05:45:39 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.107.5 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.107.5: No such image: homeassistant/qemux86-64-homeassistant:0.107.5").
20-03-22 05:45:39 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
貌似升级版本 升不了, 会提示错误  No such image  !!
20-03-22 05:45:39 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock.<locals>.wrap_api() done, defined at /usr/src/supervisor/supervisor/utils/__init__.py:22> exception=HomeAssistantUpdateError()>
发表于 2020-3-25 23:57:03 | 显示全部楼层
谢谢分享
发表于 2020-3-26 00:58:49 | 显示全部楼层
这个就有点厉害了!
GMT+8, 2025-12-16 20:00 , Processed in 1.237238 second(s), 17 queries , MemCached On.
