群晖DSM安装Hassio(非虚拟机)此方法暂已弃用
发表于 2019-7-4 15:02:35 | 显示全部楼层
看一看搞啥子
发表于 2019-7-4 15:28:59 | 显示全部楼层
这是怎么做到的。
Mrlu
发表于 2019-7-4 15:42:40 | 显示全部楼层
第三方?
发表于 2019-7-4 16:43:26 | 显示全部楼层
看看怎么安装。。。 性能如何
发表于 2019-7-4 17:05:55 | 显示全部楼层
谢谢分享aaa
发表于 2019-7-4 17:10:00 | 显示全部楼层
看看怎么玩的
发表于 2019-7-4 17:12:07 | 显示全部楼层
大神,重启一遍群晖就可以进入hassio界面了,但是hassio日志显示19-07-03 06:40:53 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-07-03 06:40:54 ERROR (MainThread) [hassio.utils.json] Can't read json from /data/addons/git/a0d7b954/repository.json: [Errno 2] No such file or directory: '/data/addons/git/a0d7b954/repository.json'
19-07-03 18:41:07 ERROR (MainThread) [hassio.store.git] Can't update https://github.com/hassio-addons/repository repo: Cmd('git') failed due to: exit code(128)
  cmdline: git fetch --depth=1 --update-shallow -v origin
  stderr: 'fatal: Unable to create '/data/addons/git/a0d7b954/.git/shallow.lock': File exists.
Another git process seems to be running in this repository, e.g.
an editor opened by 'git commit'. Please make sure all processes
are terminated then try again. If it still fails, a git process
may have crashed in this repository earlier:
remove the file manually to continue.'.
发表于 2019-7-4 17:14:28 | 显示全部楼层
发现重启一次群晖就可以进入hassio了
发表于 2019-7-4 17:14:31 | 显示全部楼层
我来学下下
发表于 2019-7-4 17:26:09 | 显示全部楼层
我怎么不能下载呢  是不是注册时间太短啊
GMT+8, 2026-1-13 12:48 , Processed in 1.731384 second(s), 16 queries , MemCached On.
