楼主:
HASS+HomeKit智能家居控制——视频展(zhuang)示(bi)贴
最佳新人
发表于 2017-8-3 16:26:25 | 显示全部楼层
支持下  6总 很6啊
发表于 2017-8-3 17:38:57 | 显示全部楼层
懒是人类进步的动力
wqqs 手机认证
活跃会员
发表于 2017-8-3 22:23:16 | 显示全部楼层
霸气侧漏啊
发表于 2017-8-4 09:25:16 | 显示全部楼层
玩得很溜啊~
发表于 2017-8-4 09:32:39 | 显示全部楼层
如果每个视频后面都跟上教程的链接就完美了
发表于 2017-8-4 10:23:12 | 显示全部楼层
楼主好,我运行homebridge的时候出现了下面的警告,username 和 host 我都确认过填的是我自己pi的MAC地址 及 IP 地址。一晚上都在折腾这个,实在没招了故来求助
pi@hassbian:~ $ homebridge
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... =DNSServiceRegister>
[8/1/2017, 1:39:59 PM] Loaded plugin: homebridge-homeassistant
[8/1/2017, 1:39:59 PM] Registering platform 'homebridge-homeassistant.HomeAssistant'
[8/1/2017, 1:39:59 PM] ---
/usr/lib/node_modules/homebridge/lib/server.js:205
      throw new Error('Not a valid username: ' + username + '. Must be 6 pairs of colon-' +
Error: Not a valid username: x:x:x:x:x:x. Must be 6 pairs of colon-separated hexadecimal chars (A-F 0-9), like a MAC address.
    at Server._loadConfig (/usr/lib/node_modules/homebridge/lib/server.js:205:13)
    at new Server (/usr/lib/node_modules/homebridge/lib/server.js:52:38)
    at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:26:16)
    at Object.<anonymous> (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.runMain (module.js:604:10)
 楼主| 发表于 2017-8-4 10:31:54 | 显示全部楼层
iamsmallk 发表于 2017-8-4 10:23
楼主好,我运行homebridge的时候出现了下面的警告,username 和 host 我都确认过填的是我自己pi的MAC地址  ...
username绝对有问题,你贴出来!以后问问题,把配置和错误都截图贴出来,养成好习惯。
iLee
iLee
发表于 2017-8-4 10:56:08 | 显示全部楼层
智能锁用的哪款?
发表于 2017-8-4 11:59:29 | 显示全部楼层
Jones 发表于 2017-8-4 10:31
Not a valid username: x:x:x:x:x:x. Must be 6 pairs of colon-separated hexadecimal chars (A-F 0-9), ...
谢谢Jones的提醒,我以后会注意提问格式的哈。
错误截图及配置如下:
Freddy.
最佳新人卓越贡献
发表于 2017-8-4 13:57:39 | 显示全部楼层
支持一下!~
GMT+8, 2026-1-18 13:28 , Processed in 0.857844 second(s), 14 queries , MemCached On.
