楼主: zyboy3707
[求助] 新手,群晖安装HA0.52,小米网关添加不上指点,怎么解决。
 楼主| 发表于 2017-8-3 19:39:02 | 显示全部楼层
wqqs 发表于 2017-8-3 12:55
缺少依赖的组件,试试手动安装这些组件
2017-08-03 19:11:03 INFO (Thread-9) [homeassistant.util.package] Attempting install of https://github.com/Danielhiverse ... iaomiGateway==0.2.0
2017-08-03 19:11:03 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.1 seconds.
2017-08-03 19:11:03 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=automation>
2017-08-03 19:12:58 ERROR (Thread-9) [homeassistant.util.package] Unable to install package https://github.com/Danielhiverse ... aomiGateway==0.2.0: Command "/volume1/@appstore/py3k/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-5v0wcexs/pyCrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-o5uji5zk-record/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-5v0wcexs/pyCrypto/
2017-08-03 19:12:58 ERROR (MainThread) [homeassistant.setup] Not initializing xiaomi because could not install dependency https://github.com/Danielhiverse ... iaomiGateway==0.2.0
2017-08-03 19:12:58 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi: Could not install all requirements.
求教 手动安装命令是这么写,
是缺少那些组件。。
 楼主| 发表于 2017-8-3 21:53:13 | 显示全部楼层
手动安装 pycrypto 出错, 有高手帮忙解决么
手动按照命令是 sudo python3 -m  pip install pycrypto
下面是安装部分日志
 楼主| 发表于 2017-8-8 16:55:44 | 显示全部楼层
无法解决, 最终办法把ha 安装在chroot环境下。
安装教程 https://home-assistant.io/docs/installation/virtualenv/
GMT+8, 2026-2-1 13:08 , Processed in 0.363055 second(s), 7 queries , MemCached On.
