查看: 30403|回复: 30
20块自制空调红外带反馈
发表于 2019-6-16 04:06:11 | 显示全部楼层 |阅读模式
我是搬运工, 我是搬运工, 我是搬运工!    这是Huex大佬的杰作,我只是个抄作业的。
一直以来,红外遥控被吐槽,无论是你买的博联还是其它红外,多数只能单向,接收器也只是拿来学习,市面唯一知道的也就是小米的空调可以做到接收发送同步,但是今天IRremoteMQTT也做到了!虽然目前支持不是很多,但实际上这是一项复杂的工程,没有各位的参与是不可能完成的!
如何确定空调是否支持?首先,你必须准备好一块ESP8266,mini D1是个好选择,一枚红外接收管,最好的办法就是借拆一枚,分别接好线,将OUT脚接入到esp8266 gpio14 [D5]  VCC接5V供电Gnd接Gnd。将以下bin文件刷入,刷入完成后,使用TTL串口工具查看串口信息,(可以用putty,)
IRrecvDumpV2.ino.generic (1).zip (235.01 KB, 下载次数: 195)
接下来是你展示你遥控器的时候了,按下你的遥控器,TTL显示类似如下信息:
Timestamp : 006910.551
Encoding  : PANASONIC_AC
Code      : 0220E004000000060220E00400313680A100000660000085000079 (216 bits)
Mesg Desc.: Model: 4 (JKE), Power: On, Mode: 3 (COOL), Temp: 27C, Fan: 7 (AUTO), Swing (Vertical): 1 (Full Up), Quiet: Off, Powerful: Off, Clock: 0:00, On Timer: Off, Off Timer: Off
Library   : v2.6.0
Raw Timing[439]:
   +  3548, -  1702,    +   480, -   398,    +   426, -  1304,    +   508, -   400,
   +   478, -   404,    +   480, -   400,    +   480, -   404,    +   480, -   400,
   +   428, -   462,    +   428, -   452,    +   428, -   454,    +   428, -   454,
   +   428, -   454,    +   428, -   454,    +   428, -  1302,    +   428, -   454,
   +   428, -   462,    +   428, -   452,    +   426, -   454,    +   426, -   454,
   +   428, -   454,    +   428, -   454,    +   426, -  1306,    +   478, -  1252,
   +   428, -  1312,    +   480, -   402,    +   428, -   454,    +   426, -  1304,
   +   428, -   454,    +   428, -   454,    +   426, -   454,    +   428, -   454,
   +   426, -   462,    +   428, -   452,    +   426, -   454,    +   480, -   402,
   +   428, -   456,    +   428, -   454,    +   426, -   454,    +   428, -   456,
   +   426, -   464,    +   428, -   452,    +   428, -   454,    +   428, -   454,
   +   426, -   456,    +   426, -   454,    +   428, -   454,    +   426, -   456,
   +   452, -   438,    +   454, -   448,    +   428, -   454,    +   426, -   456,
   +   428, -   456,    +   426, -   454,    +   426, -   454,    +   428, -   454,
   +   428, -   464,    +   426, -   454,    +   426, -  1304,    +   428, -  1302,
   +   426, -   456,    +   426, -   454,    +   428, -   454,    +   428, -   454,
   +   428, -   462,    +   436, - 10992,    +  3548, -  1700,    +   428, -   452,
   +   478, -  1252,    +   428, -   454,    +   480, -   402,    +   428, -   454,
   +   480, -   402,    +   480, -   402,    +   480, -   410,    +   428, -   450,
   +   480, -   402,    +   430, -   452,    +   426, -   456,    +   480, -   402,
   +   478, -  1250,    +   428, -   454,    +   428, -   464,    +   478, -   400,
   +   480, -   402,    +   428, -   454,    +   480, -   402,    +   428, -   454,
   +   480, -  1250,    +   480, -  1250,    +   428, -  1310,    +   480, -   400,
   +   480, -   400,    +   428, -  1304,    +   478, -   404,    +   480, -   402,
   +   426, -   456,    +   478, -   402,    +   480, -   410,    +   482, -   398,
   +   478, -   404,    +   426, -   456,    +   478, -   410,    +   478, -  1250,
   +   426, -   454,    +   428, -   456,    +   426, -   454,    +   480, -  1250,
   +   428, -  1304,    +   478, -   404,    +   426, -   462,    +   482, -   398,
   +   428, -  1302,    +   428, -  1304,    +   426, -   456,    +   478, -  1252,
   +   428, -  1302,    +   426, -   454,    +   428, -   462,    +   428, -   452,
   +   428, -   454,    +   478, -   404,    +   478, -   404,    +   426, -   454,
   +   478, -   402,    +   480, -   402,    +   428, -  1312,    +   434, -  1292,
   +   480, -   402,    +   426, -   454,    +   480, -   402,    +   478, -   402,
   +   482, -  1250,    +   478, -   404,    +   480, -  1258,    +   480, -   400,
   +   480, -   402,    +   478, -   406,    +   428, -   454,    +   482, -   400,
   +   482, -   400,    +   480, -   402,    +   482, -   408,    +   480, -   400,
   +   480, -   400,    +   480, -   400,    +   480, -   402,    +   482, -   400,
   +   480, -   402,    +   480, -   402,    +   482, -   408,    +   482, -   396,
   +   482, -  1250,    +   482, -  1250,    +   480, -   402,    +   482, -   400,
   +   480, -   402,    +   480, -   402,    +   480, -   412,    +   480, -   398,
   +   480, -   400,    +   480, -   400,    +   482, -   400,    +   482, -   400,
   +   480, -  1250,    +   482, -  1250,    +   480, -   408,    +   480, -   400,
   +   478, -   402,    +   482, -   400,    +   452, -   430,    +   480, -   400,
   +   480, -   402,    +   480, -   402,    +   480, -   410,    +   482, -   398,
   +   480, -   402,    +   480, -   402,    +   428, -   456,    +   428, -   452,
   +   482, -   402,    +   428, -   454,    +   482, -   408,    +   482, -  1244,
   +   482, -   400,    +   480, -  1250,    +   508, -   376,    +   480, -   400,
   +   482, -   400,    +   480, -   400,    +   428, -  1310,    +   482, -   398,
   +   428, -   452,    +   482, -   400,    +   482, -   402,    +   482, -   400,
   +   482, -   400,    +   482, -   400,    +   480, -   410,    +   480, -   398,
   +   482, -   400,    +   482, -   402,    +   480, -   416,    +   480, -  1246,
   +   484, -   400,    +   480, -   400,    +   480, -  1250,    +   482, -  1248,
   +   480, -  1250,    +   482, -  1250,    +   482, -   408,    +   482
uint16_t rawData[439] = {3548, 1702,  480, 398,  426, 1304,  508, 400,  478, 404,  480, 400,  480, 404,  480, 400,  428, 462,  428, 452,  428, 454,  428, 454,  428, 454,  428, 454,  428, 1302,  428, 454,  428, 462,  428, 452,  426, 454,  426, 454,  428, 454,  428, 454,  426, 1306,  478, 1252,  428, 1312,  480, 402,  428, 454,  426, 1304,  428, 454,  428, 454,  426, 454,  428, 454,  426, 462,  428, 452,  426, 454,  480, 402,  428, 456,  428, 454,  426, 454,  428, 456,  426, 464,  428, 452,  428, 454,  428, 454,  426, 456,  426, 454,  428, 454,  426, 456,  452, 438,  454, 448,  428, 454,  426, 456,  428, 456,  426, 454,  426, 454,  428, 454,  428, 464,  426, 454,  426, 1304,  428, 1302,  426, 456,  426, 454,  428, 454,  428, 454,  428, 462,  436, 10992,  3548, 1700,  428, 452,  478, 1252,  428, 454,  480, 402,  428, 454,  480, 402,  480, 402,  480, 410,  428, 450,  480, 402,  430, 452,  426, 456,  480, 402,  478, 1250,  428, 454,  428, 464,  478, 400,  480, 402,  428, 454,  480, 402,  428, 454,  480, 1250,  480, 1250,  428, 1310,  480, 400,  480, 400,  428, 1304,  478, 404,  480, 402,  426, 456,  478, 402,  480, 410,  482, 398,  480, 402,  428, 454,  480, 402,  428, 454,  478, 404,  426, 456,  478, 410,  478, 1250,  426, 454,  428, 456,  426, 454,  480, 1250,  428, 1304,  478, 404,  426, 462,  482, 398,  428, 1302,  428, 1304,  426, 456,  478, 1252,  428, 1302,  426, 454,  428, 462,  428, 452,  428, 454,  478, 404,  478, 404,  426, 454,  478, 402,  480, 402,  428, 1312,  434, 1292,  480, 402,  426, 454,  480, 402,  478, 402,  482, 1250,  478, 404,  480, 1258,  480, 400,  480, 402,  478, 406,  428, 454,  482, 400,  482, 400,  480, 402,  482, 408,  480, 400,  480, 400,  480, 400,  480, 402,  482, 400,  480, 402,  480, 402,  482, 408,  482, 396,  482, 1250,  482, 1250,  480, 402,  482, 400,  480, 402,  480, 402,  480, 412,  480, 398,  480, 400,  480, 400,  482, 400,  482, 400,  480, 1250,  482, 1250,  480, 408,  480, 400,  478, 402,  482, 400,  452, 430,  480, 400,  480, 402,  480, 402,  480, 410,  482, 398,  480, 402,  480, 402,  428, 456,  428, 452,  482, 402,  428, 454,  482, 408,  482, 1244,  482, 400,  480, 1250,  508, 376,  480, 400,  482, 400,  480, 400,  428, 1310,  482, 398,  428, 452,  482, 400,  482, 402,  482, 400,  482, 400,  482, 400,  480, 410,  480, 398,  480, 400,  480, 400,  482, 400,  482, 400,  482, 400,  482, 402,  480, 416,  480, 1246,  484, 400,  480, 400,  480, 1250,  482, 1248,  480, 1250,  482, 1250,  482, 408,  482};  // PANASONIC_AC
uint8_t state[27] = {0x02, 0x20, 0xE0, 0x04, 0x00, 0x00, 0x00, 0x06, 0x02, 0x20, 0xE0, 0x04, 0x00, 0x31, 0x36, 0x80, 0xA1, 0x00, 0x00, 0x06, 0x60, 0x00, 0x00, 0x85, 0x00, 0x00, 0x79};
在以上信息中,我们可以看到decode Mesg Desc.: 信息,展示了目前遥控的代码和结构,如果你的遥控器按下后生成类似消息 ,那么恭喜你,你的空调代码无损支持,并且使用此源码将可以使用MQTT来同步显示和操作空调,所有遥控操作将同步到MQTT消息中。
然而如果你的是这样的:
Timestamp : 007100.353
Encoding  : UNKNOWN
Code      : 9BBD013B (106 bits)
Library   : v2.6.0
Raw Timing[211]:
   +  9010, -  4648,    +   456, -  1854,    +   428, -  1854,    +   430, -   698,
   +   402, -   648,    +   454, -   700,    +   426, -   674,    +   426, -  1780,
   +   456, -  1798,    +   456, -   730,    +   402, -   644,    +   426, -   730,
   +   220, -  2010,    +   296, -   776,    +   430, -   700,    +   374, -   728,
   +   404, -  1852,    +   430, -   620,    +   454, -   648,    +   454, -   674,
   +   456, -   618,    +   458, -   672,    +   428, -  1828,    +   430, -  1804,
   +   452, -  1828,    +   428, -   700,    +   324, -   750,    +   428, -   652,
   +   454, -   694,    +   402, -   700,    +   418, -   684,    +   430, -   672,
   +   430, -   648,    +   426, -   648,    +   452, -   766,    +   364, -   726,
   +   296, -   698,    +   456, -   700,    +   350, -  1878,    +   432, -   674,
   +   380, -  1872,    +   430, -   644,    +   454, -   702,    +   402, -   674,
   +   454, -   672,    +   406, -   644,    +   482, -   646,    +   428, -   700,
   +   404, -   698,    +   402, -   644,    +   456, -   754,    +   348, -   672,
   +   458, -   616,    +   458, -   670,    +   404, -   726,    +   402, -   726,
   +   376, -  1828,    +   430, -   698,    +   404, -   750,    +   380, -   616,
   +   432, -   724,    +   400, -   702,    +   426, -   674,    +   406, -   644,
   +   456, -   776,    +   402, -   726,    +   402, -   674,    +   376, -   674,
   +   454, -   724,    +   378, -   700,    +   378, -   766,    +   360, -   670,
   +   432, -   670,    +   430, -   674,    +   406, -   692,    +   432, -   674,
   +   452, -   726,    +   326, -   724,    +   428, -  1776,    +   478, -   678,
   +   402, -   698,    +   428, -   620,    +   458, -   724,    +   376, -   674,
   +   376, -   698,    +   456, -   698,    +   376, -   728,    +   402, -   700,
   +   378, -   790,    +   336, -   644,    +   454, -  1828,    +   430, -  1802,
   +   454, -   674,    +   454, -   672,    +   402, -   674,    +   428, -   700,
   +   424, -   676,    +   404, -  1800,    +   430, -   698,    +   430, -   672,
   +   458, -   644,    +   428, -  1856,    +   402, -  1802,    +   458, -  1800,
   +   456, -   644,    +   456
uint16_t rawData[211] = {9010, 4648,  456, 1854,  428, 1854,  430, 698,  402, 648,  454, 700,  426, 674,  426, 1780,  456, 1798,  456, 730,  402, 644,  426, 730,  220, 2010,  296, 776,  430, 700,  374, 728,  404, 1852,  430, 620,  454, 648,  454, 674,  456, 618,  458, 672,  428, 1828,  430, 1804,  452, 1828,  428, 700,  324, 750,  428, 652,  454, 694,  402, 700,  418, 684,  430, 672,  430, 648,  426, 648,  452, 766,  364, 726,  296, 698,  456, 700,  350, 1878,  432, 674,  380, 1872,  430, 644,  454, 702,  402, 674,  454, 672,  406, 644,  482, 646,  428, 700,  404, 698,  402, 644,  456, 754,  348, 672,  458, 616,  458, 670,  404, 726,  402, 726,  376, 1828,  430, 698,  404, 750,  380, 616,  432, 724,  400, 702,  426, 674,  406, 644,  456, 776,  402, 726,  402, 674,  376, 674,  454, 724,  378, 700,  378, 766,  360, 670,  432, 670,  430, 674,  406, 692,  432, 674,  452, 726,  326, 724,  428, 1776,  478, 678,  402, 698,  428, 620,  458, 724,  376, 674,  376, 698,  456, 698,  376, 728,  402, 700,  378, 790,  336, 644,  454, 1828,  430, 1802,  454, 674,  454, 672,  402, 674,  428, 700,  424, 676,  404, 1800,  430, 698,  430, 672,  458, 644,  428, 1856,  402, 1802,  458, 1800,  456, 644,  456};  // UNKNOWN 9BBD013B
很遗憾,两种情况,一种库不包含这种空调代码,另外一种情况,源码包含了这个品牌,但解码长度和值不对,针对这种情况你可以 收集一操作 然后把操作注明,提交issue给作者,他可以根据你的操作和原始值分析码长和值的一些情况
需要指出的是,由于空调厂家变动一些代码阀值,部分显示也会unknow,但是刷完IRMQTTSERVER固件后,仍然可以控制空调,却不能Decode解析,此类情况请参考上面的分析完所有的操作原始值,提交给作者修改码长和阀值等信息
喜普大奔,支持了怎么用?
下载到arduino库,示例IRMQTTSERVER,对应编译即可。使用编译请修改IRMQTTSERVER.h文件中的IR_LED 和IR_RX ,其对应的是发射脚IO和接收IO
不会操作,请下载:
IRMQTTServer.ino.generic.zip (329.15 KB, 下载次数: 124)
下载已经编译的固件请:
红外发射管请 GND接GPIO16 [短脚]     Vcc接 电源3V[长脚]  ,接收管out脚接 GPIO14  Vcc Gnd 各自对应
刷入完成后,上电默认AP模式,手机连入后配网操作,务必配置MQTT,配置完成后,可使用IP进入IRMQTTSERVER ,操作如下图
请务必确认你的测试是可以发码的,使用手机摄像头对着红外管,操作后有灯闪表示发码成功,所有操作均无灯闪请检查自己的GPIO接线及发射管,目前已发现有部分发射管不发射成功。
使用AIRCON操作的时候,如果你的空调不支持swing v&H 扫风模式,请不要开启,所有功能空调没有的,均不要开启,否则发码不成功!
操作时model可以默认,没有反应可以再选择1、2、3、4、5、6,均无反应则PASS,不支持
MQTT
至于接入方面,通过上图,大概你们也清楚,设备网页info里也已经展示。调用接口均匀 已经出现,不明白可以参考
climate:
  platform: mqtt
  name: Living Room Aircon
  modes:
    - "off"
    - "auto"
    - "cool"
    - "heat"
    - "dry"
    - "fan_only"
  fan_modes:
    - "auto"
    - "min"
    - "low"
    - "medium"
    - "high"
    - "max"
  swing_modes:
    - "off"
    - "auto"
    - "highest"
    - "high"
    - "middle"
    - "low"
    - "lowest"
  power_command_topic: "ir_server/ac/cmnd/power"
  mode_command_topic: "ir_server/ac/cmnd/mode"
  mode_state_topic: "ir_server/ac/stat/mode"
  temperature_command_topic: "ir_server/ac/cmnd/temp"
  temperature_state_topic: "ir_server/ac/stat/temp"
  fan_mode_command_topic: "ir_server/ac/cmnd/fanspeed"
  fan_mode_state_topic: "ir_server/ac/stat/fanspeed"
#  swing_mode_command_topic: "ir_server/ac/cmnd/swingv"
#  swing_mode_state_topic: "ir_server/ac/stat/swingv"
  min_temp: 16
  max_temp: 32
  temp_step: 1
  retain: false
有测试OK的基友,请贴出你的遥控器型号及图片,thanks,,,,
参与人数 2金钱 +40 HASS币 +10 收起 理由
jyz_0501 + 20 论坛有你更精彩!
+ 20 + 10 厉害了word楼主!
流水无味
灌水之王
发表于 2019-6-16 09:10:20 | 显示全部楼层
这个不错
跟小米空调网关识别红外一个原理
发表于 2019-6-16 11:40:55 | 显示全部楼层
火前留名 继续学习 大牛的神技
发表于 2019-6-16 14:51:40 | 显示全部楼层
这个东西真的好啊。
发表于 2019-6-16 17:15:34 | 显示全部楼层
柜机的按键操作反馈有木有办法
发表于 2019-6-16 21:31:27 | 显示全部楼层
还是没看到怎么反馈......空调怎么反馈说已经接收到红外码并执行?
自带的遥控器有干扰或者偏一点都不能识别,这个
发表于 2019-6-16 23:47:31 | 显示全部楼层
这样反馈的信息依旧会有点问题 最方便的其实还是功率监控
发表于 2019-6-17 19:35:32 | 显示全部楼层
收藏后慢慢研究
发表于 2019-6-22 15:37:01 | 显示全部楼层
看看,继续学习!
发表于 2019-6-22 21:25:55 | 显示全部楼层
学习下
GMT+8, 2025-12-23 17:13 , Processed in 0.627395 second(s), 12 queries , MemCached On.
